查看: 3399|回复: 2
xilinx pci32 logic core question????
发表于 2005-2-5 13:18:57 | 显示全部楼层 |阅读模式
我用ISE63综合时
发现它不支持
primitice hshsh(******,******,******,*****)
input   *******,*****;
output  ******,******;
table
   # ********       ********          8888888  : *******
endtable
endprimitive
请问是什么原因啊?
例:
//    Xilinx Proprietary Primitive Cell X_FF for Verilog
// $Header: /devl/xcs/repo/env/Databases/CAEInterfaces/versclibs/data/Attic/X_FF.v,v 1.25.2.4 2003/12/10 18:44:36 wloo Exp $
`timescale 1 ps/1 ps
module X_FF (O, CE, CLK, I, RST, SET);
  parameter INIT = 1'b0;
  output O;
  input CE, CLK, I, RST, SET;
  wire ni, nrst, nset, in_out;
  wire in_clk_enable, ce_clk_enable, rst_clk_enable, set_clk_enable;
  reg notifier;
  not (ni, I);
  not (nrst, RST);
  not (nset, SET);
  xor (in_out, I, O);
  and (in_clk_enable, nrst, nset, CE);
  and (ce_clk_enable, nrst, nset, in_out);
  and (rst_clk_enable, CE, I);
  and (set_clk_enable, CE, nrst, ni);
  ffsrce (O, CLK, I, CE, SET, RST, notifier);
  specify
(CLK => O) = (100:100:100, 100:100:100);
(SET => O) = (0:0:0, 0:0:0);
(RST => O) = (0:0:0, 0:0:0);
$setuphold (posedge CLK, posedge CE &&& (ce_clk_enable!=0), 0:0:0, 0:0:0, notifier);
$setuphold (posedge CLK, negedge CE &&& (ce_clk_enable!=0), 0:0:0, 0:0:0, notifier);
$setuphold (posedge CLK, posedge I &&& (in_clk_enable!=0), 0:0:0, 0:0:0, notifier);
$setuphold (posedge CLK, negedge I &&& (in_clk_enable!=0), 0:0:0, 0:0:0, notifier);
$recrem (negedge RST, posedge CLK &&& (rst_clk_enable!=0), 0:0:0, 0:0:0, notifier);
$recrem (negedge SET, posedge CLK &&& (set_clk_enable!=0), 0:0:0, 0:0:0, notifier);
$period (posedge CLK &&& CE, 0:0:0, notifier);
$width (posedge RST, 0:0:0, 0, notifier);
$width (posedge SET, 0:0:0, 0, notifier);
specparam PATHPULSE$ = 0;
  endspecify
endmodule
primitive ffsrce (q, clk, d, ce, set, rst, notifier);
  output q; reg q;
  input clk, d, ce, set, rst, notifier;
  table
    //   clk    d     ce   set   rst   notifier    q     q+;
          ?     ?      ?    1     0       ?    :   ?  :  1;
          ?     ?      ?    ?     1       ?    :   ?  :  0;
         (01)   0      1    0     0       ?    :   ?  :  0;
         (01)   1      1    0     0       ?    :   ?  :  1;
         (01)   x      1    0     0       ?    :   ?  :  x;
         (01)   0      x    0     0       ?    :   0  :  0;
         (01)   1      x    0     0       ?    :   1  :  1;
         (??)   ?      0    ?     ?       ?    :   ?  :  -;
         (1?)   ?      ?    ?     ?       ?    :   ?  :  -;
         (?0)   ?      ?    ?     ?       ?    :   ?  :  -;
         (01)   0      1    0     x       ?    :   ?  :  0;
         (01)   1      1    x     0       ?    :   ?  :  1;
          ?     ?      ?    0    (?x)     ?    :   0  :  0;
          ?     ?      ?   (?x)   0       ?    :   1  :  1;
         (?1)   1      ?    ?     0       ?    :   1  :  1;
         (?1)   0      ?    0     ?       ?    :   0  :  0;
         (0?)   1      ?    ?     0       ?    :   1  :  1;
         (0?)   0      ?    0     ?       ?    :   0  :  0;
          ?     ?      ?   (?0)   ?       ?    :   ?  :  -;
          ?     ?      ?    x    (?0)     ?    :   ?  :  x;
          ?     ?      ?    0    (?0)     ?    :   ?  :  -;
          ?     ?      ?    ?     ?       *    :   ?  :  x;
  endtable
endprimitive
发表于 2005-3-6 18:47:10 | 显示全部楼层
这位大哥,能否将你用得IPcore发给我一份,我目前也需要再vertex2上面做一个PCI但是没有钱去买license麻烦你帮帮忙!谢谢!
发表于 2005-3-7 20:25:03 | 显示全部楼层
我也需要一个,也送我一个吧!
GMT+8, 2025-12-18 20:57 , Processed in 0.018252 second(s), 6 queries , Gzip On, Redis On.
