查看: 28643|回复: 95
[资料] JSSC_3月的High PSRR LDO
发表于 2010-4-17 21:27:44 | 显示全部楼层 |阅读模式
Abstract—A low drop-out (LDO) regulator with a feed-forward
ripple cancellation (FFRC) technique is proposed in this paper.
The FFRC-LDO achieves a high power-supply rejection (PSR)
over a wide frequency range. Complete analysis and design steps
of the FFRC-LDO are presented in this paper.Kelvin connection is
also used to increase the gain–bandwidth of the LDO allowing for
faster transient performance. The LDO is implemented in 0.13 m
CMOS technology and achieves a PSR better than 56 dB up to
10 MHz for load currents up to 25 mA. Load regulation of 1.2 mV
for a 25 mA step is measured, and the whole LDO consumes
a quiescent current of 50 A with a bandgap reference circuit
included. To our knowledge, this is the first LDO that achieves
such a high PSR up to 10 MHz.
High_PSR_Low_Drop-Out_Regulator_With_Feed-Forward_Ripple_Cancellation_Technique.pdf
1.64 MB, 下载次数: 1005 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-4-17 21:30:51 | 显示全部楼层
kankan bu cuo
发表于 2010-4-18 23:33:18 | 显示全部楼层
很好,谢谢
发表于 2010-4-18 23:48:23 | 显示全部楼层
thanks
发表于 2010-4-20 01:25:42 | 显示全部楼层
good... thank you
发表于 2010-4-20 01:54:47 | 显示全部楼层
好东西。。
发表于 2010-5-11 13:26:11 | 显示全部楼层
DDDDDDDDDDDDDDDDD
发表于 2010-5-11 14:14:40 | 显示全部楼层
最近正为PSRR困扰着呢
发表于 2010-5-11 14:21:06 | 显示全部楼层
thanks!
发表于 2010-5-11 23:07:15 | 显示全部楼层
thanks for it
GMT+8, 2025-12-18 06:35 , Processed in 0.025380 second(s), 8 queries , Gzip On, Redis On.
