查看: 5925|回复: 4
[求助] Question about set_toggle_region when I work with saif
发表于 2010-3-25 23:30:24 | 显示全部楼层 |阅读模式
I have created the forward annotation file in dc_shell (/rtl2saif
forward.saif/) and import it into modelsim by dpfli.so library using
the command "vsim -foreign "dpfli_init
/lsc/synopsys/syn-2005.09/auxx/syn/power/dpfli/lib-linux/dpfli.so" -c
-quiet tbgen" with no problems
Modelsim reads ok that file but when i try to set_toggle_region i have
a lot of message like:
"can't find signal error...skipping "
so the back annotation file is almost empty (toggle_report back.saif....)
Anyone knows where is the problem?Thanks for you help
 楼主| 发表于 2010-3-26 10:29:26 | 显示全部楼层
I have solved it,not dpfli.so,it is libvpower.so,
the difference between them,I am not very sure!
发表于 2010-5-29 14:55:59 | 显示全部楼层
2# TomPaul Thank u very much! I'll try your means!
发表于 2011-2-23 19:23:24 | 显示全部楼层
回复 1# TomPaul
    Is the  foreign initialization function still the dpfli_init?
    I use the command:
vsim -novopt -foreign "dpfli_init /eda/synopsys/dc/auxx/syn/power/vpower/lib-linux/libvpower.so" -c -quiet test
But the result is:
# ** Warning: (vsim-FLI-3159) Failed to find foreign initialization function 'dpfli_init' in FLI object file "/eda/synopsys/dc/auxx/syn/power/vpower/lib-linux/libvpower.so".
What can I do?
发表于 2012-5-20 20:27:14 | 显示全部楼层
回复 1# TomPaul
同问,我也遇到这个问题,请问是怎么解决的?
GMT+8, 2025-12-22 16:01 , Processed in 0.016541 second(s), 5 queries , Gzip On, Redis On.
