楼主: gongxuwhu
[讨论] PSRR探讨
发表于 2015-9-19 03:23:30 | 显示全部楼层
非常感谢各位大师指点
发表于 2019-5-10 15:43:06 | 显示全部楼层
路过,感谢楼主分享!!!
发表于 2019-5-30 18:26:33 | 显示全部楼层
路过~~
发表于 2019-6-4 19:00:05 | 显示全部楼层
liuguojia612 发表于 2010-3-26 13:47
according to your opinions,if vb1 and vb2 always keep constant (as in the case that they are biase ...
YES, it will be worse. if you use the gm/id methode, you will know this problem cleaarly. If the VB1 and the VB2 are fixed, when the VDD changes, the current source can not keep its current constant. The current will be changed and the situation of you circuit will also be changed. That means the variation of the VDD will affect the circuit. we can say the PSRR is not good.
发表于 2021-6-4 11:57:03 | 显示全部楼层
看看
发表于 2021-6-29 17:26:12 | 显示全部楼层
fcm5658779 发表于 2019-6-4 19:00
YES, it will be worse. if you use the gm/id methode, you will know this problem cleaarly. If the  ...
bias 的栅端不能与VDD扰动反向么?
GMT+8, 2025-9-16 13:53 , Processed in 1.693574 second(s), 3 queries , Gzip On, Redis On.
