楼主: zczc999
[求助] 请教fanout与cell delay
发表于 2014-5-15 14:13:10 | 显示全部楼层
发表于 2014-5-15 16:43:37 | 显示全部楼层
回复 21# herrzhou
   design rule violation,就是max_transition,max_cap,max_fanout之类
发表于 2014-5-21 22:57:30 | 显示全部楼层
回复  herrzhou
王不动 发表于 2014-5-15 16:43
谢谢,为什么有fanout violation?有max_transition,max_cap,max_fanout不就够了吗
发表于 2016-8-16 11:43:20 | 显示全部楼层
回复 23# herrzhou
  fanout不是hard rule!trans cap才是hard rule!
发表于 2016-8-16 11:44:37 | 显示全部楼层
回复 18# lulanlanily
   依稀记得是:T=ax+by+cxy。x和y是trans和cap!
发表于 2016-8-16 11:47:26 | 显示全部楼层
回复 7# icfbicfb
    个人觉得你说的不太对,slew应该是output和input一样的。 你说的net rc 和 load 应该只会影响讯号的delay值!
发表于 2022-2-2 11:24:30 | 显示全部楼层
In digital electronics, Fan-out of 4 is a measure of time used in digital CMOS technologies: the gate delay of a component with a fan-out of 4.
Fan out = Cload / Cin, where
Cload = total MOS gate capacitance driven by the logic gate under consideration
Cin = the MOS gate capacitance of the logic gate under consideration
As a delay metric, one FO4 is the delay of an inverter, driven by an inverter 4x smaller than itself, and driving an inverter 4x larger than itself. Both conditions are necessary since input signal rise/fall time affects the delay as well as output loading.
FO4 is generally used as a delay metric because such a load is generally seen in case of tapered buffers driving large loads, and approximately in any logic gate of a logic path sized for minimum delay. Also, for most technologies the optimum fanout for such buffers generally varies from 2.7 to 5.3.[1]
A fan out of 4 is the answer to the canonical problem stated as follows: Given a fixed size inverter, small in comparison to a fixed large load, minimize the delay in driving the large load. After some math, it can be shown that the minimum delay is achieved when the load is driven by a chain of N inverters, each successive inverter ~4x larger than the previous; N ~ log4(Cload/Cin)
GMT+8, 2025-9-17 04:07 , Processed in 0.014743 second(s), 5 queries , Gzip On, Redis On.
