查看: 36926|回复: 112
[资料] 2010年3月JSSC 高PSRR LDO文章(>60dB@1 MHz)
发表于 2010-3-6 17:24:16 | 显示全部楼层 |阅读模式
High PSR Low Drop-Out Regulator With Feed-Forward Ripple Cancellation Technique.pdf (1.64 MB , 下载次数: 1945 )
发表于 2010-3-6 19:54:46 | 显示全部楼层
谢谢
看起来不错
发表于 2010-3-6 22:11:29 | 显示全部楼层
thanks
发表于 2010-3-14 14:16:55 | 显示全部楼层
haoya
发表于 2010-3-14 14:30:56 | 显示全部楼层
最新20103月JSSC
http://www.eetop.cn/bbs/thread-238832-1-2.html
1、A Compact Wideband CMOS Low Noise Amplifier With Gain Flatness Enhancement
2、A Current Reuse Quadrature GPS Receiver in 0.13  um CMOS
3、5–10 Gb/s 70 mW Burst Mode AC Coupled Receiver in 90-nm CMOS
4、A 0.6-V Zero-IF/Low-IF Receiver With Integrated Fractional-N Synthesizer for 2.4-GHz ISM-Band Applications
5、A 58–65 GHz Neutralized CMOS Power Amplifier With PAE Above 10% at 1-V Supply
6、High PSR Low Drop-Out Regulator With Feed-Forward Ripple Cancellation Technique
7、A 7.1 mW, 10 GHz All Digital Frequency Synthesizer With Dynamically Reconfigured Digital Loop Filter in 90 nm CMOS Technology
8、A Low-Power Continuously-Calibrated Clock Recovery Circuit for UHF RFID EPC Class-1 Generation-2 Transponders
9、A Time-Domain SAR Smart Temperature Sensor With Curvature Compensation and a 3σ Inaccuracy of −0.4°C ∼ +0.6°C Over a 0°C to 90°C Range
10、A 0.02-mm  9-Bit 50-MS/s Cyclic ADC in 90-nm Digital CMOS Technology
11、A 12 bit 50 MS/s CMOS Nyquist A/D Converter With a Fully Differential Class-AB Switched Op-Amp
12、An 80 mW 40 Gb/s 7-Tap T/2-Spaced Feed-Forward Equalizer in 65 nm CMOS
13、All-Digital Circuits for Measurement of Spatial Variation in Digital Circuits
14、A 116 fps/74 mW Heterogeneous 3D-Media Processor for 3-D Display Applications
15、An Ultra-Low-Energy Multi-Standard JPEG Co-Processor in 65 nm CMOS With Sub/Near Threshold Supply Voltage
发表于 2010-3-14 14:32:07 | 显示全部楼层
下来看看先
发表于 2010-3-15 18:51:12 | 显示全部楼层
thanks~~~~
发表于 2010-3-15 22:36:48 | 显示全部楼层
看起来不错
发表于 2010-3-17 16:37:38 | 显示全部楼层
下来看看
发表于 2010-3-19 11:29:14 | 显示全部楼层
ddddddddddd
GMT+8, 2025-12-28 16:19 , Processed in 0.023504 second(s), 6 queries , Gzip On, Redis On.
