查看: 3623|回复: 1
[求助] 请教大家:J750能不能限流?测试时可否用外接电源?
发表于 2010-3-4 21:42:22 | 显示全部楼层 |阅读模式
我们现在测试芯片,不能正常进行,因为会超产生的急ns的电流太大。J750保护而自动停机,但是我们的芯片又是需要这么大的短暂电流的,请大家赐教,谢谢!
发表于 2010-3-10 11:01:50 | 显示全部楼层
If you mean the power, I will suggest you can connect two DPS together to double the power, or use a Buck DC to DC IC to supply such a big current. In this situation, unless your IC need more than the max voltage * max current of DPS. You don't need an extra power.
GMT+8, 2025-12-29 02:21 , Processed in 0.021965 second(s), 6 queries , Gzip On, Redis On.
