查看: 5582|回复: 1
[求助] 请高手解答quartus IP块实现fir时出现的问题
发表于 2010-3-4 21:36:28 | 显示全部楼层 |阅读模式
用ip 生成fir后 仿真时 提示如下错误,请高手帮忙解答一下
Error: Tcl error: More than 1 positional argument specified:
D:/program, files/quartus/ip/altera/fir_compiler/lib
Usage: set_global_assignment [-h | -help] [-long_help] [-comment <comment>]
[-disable] [-entity <entity_name>] -name <name> [-remove] [-section_id <section id>] [-tag <data>] [<value>]
    -h | -help: Short help
        -long_help: Long help with examples and possible return values
     -comment <comment>: Comment
        -disable: Option to disable assignment
  -entity <entity_name>: Entity to which to add assignment
        -name <name>: Assignment name
    -remove: Option to remove assignment
        -section_id <section id>: Section id
-tag <data>: Option to tag data to this assignment
        <value>: Assignment value
while executing
"set_global_assignment -name SEARCH_PATH D:/program files/quartus/ip/altera/fir_compiler/lib"
(file "fir91_ast.qip" line 12)
Info: set_global_assignment -name SEARCH_PATH `r?me -qip fir91_ast.qip
Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 0 warnings
Error: Peak virtual memory: 153 megabytes
Error: Processing ended: Thu Mar 04 21:30:33 2010
Error: Elapsed time: 00:00:00
Error: Total CPU time (on all processors): 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 3 errors, 0 warnings
发表于 2010-3-5 09:30:16 | 显示全部楼层
Quartus允许路径上有空格或汉字吗?不记得了,楼主可以试一下
GMT+8, 2025-12-17 16:41 , Processed in 0.028086 second(s), 6 queries , Gzip On, Redis On.
