查看: 18747|回复: 50
[资料] UHF RFID Antenna 资料 10篇文献小尺寸类
发表于 2010-2-21 21:21:48 | 显示全部楼层 |阅读模式
1. Design and Analysis of Efficient and Compact Antenna for Paper Based UHF RFID Tags
Design and Analysis of Efficient and Compact Antenna for Paper Based UHF RFID Tags.pdf (177.09 KB , 下载次数: 160 )
一种超薄纸质印刷天线设计
2. FRACTAL ANTENNA FOR PASSIVE UHF RFID
FRACTAL ANTENNA FOR PASSIVE UHF RFID.pdf (409.96 KB , 下载次数: 140 )
分形天线类
3. GA Optimization for RFID Broadband Antenna Applications
GA Optimization for RFID Broadband Antenna Applications.pdf (2.04 MB , 下载次数: 167 )
比较全面,从天线基础的电磁分析,到匹配,到一种meander宽带天线的设计
4. Gain-optimized self-resonant meander line antennas for RFID applications
Gain-optimized self-resonant meander line antennas for RFID applications.pdf (154.03 KB , 下载次数: 116 )
讨论不同形状的meander line天线以及他们的各种参数对比,总结的不错
5. Impedance, bandwidth, and Q of antennas
Impedance, bandwidth, and Q of antennas.pdf (1.06 MB , 下载次数: 179 )
这篇文章不是针对RFID的,是用纯理论的方法推导天线的 阻抗,带宽和Q的定义,表达式和关系,不错的工具文献
6. Modeling and simulation of a dipole antenna for UWB application using equavalent Spice circuits
abbr_65351367feb9785db8b1a3b0b5815e58.pdf (116.35 KB , 下载次数: 105 )
对宽带基本偶机子天线的建模和仿真,模型可以应用在RFID上
7. Modified meander line monopole antenna for broadband operation
Modified meander line monopole antenna for broadband operation.pdf (246.7 KB , 下载次数: 107 )
一种带宽很大的meander line天线,尺寸不大,可以考虑应用在RFID上
8. The Effect of Conductor Line to Meander Line Antenna Design
The Effect of Conductor Line to Meander Line Antenna Design.pdf (223.49 KB , 下载次数: 182 )
对meander line的金属线之间的作用进行分析
9. Optimization of silver paste printed passive UHF RFID tags
Optimization of silver paste printed passive UHF RFID tags.pdf (856.79 KB , 下载次数: 126 )
又是一篇超薄纸质印刷天线的设计
10. The art of UHF RFID antenna design_impedance matching and size-reduction techniques
The art of UHF RFID antenna design_impedance matching and size-reduction techniques.pdf (572.28 KB , 下载次数: 190 )
很好的工具书,挺长的一篇文章,里面总结了各种UHF RFID天线,以及他们的阻抗等等性能,主要还着重于如何减小尺寸,感觉很实用,特来分享一下~
发表于 2010-2-22 14:44:25 | 显示全部楼层
谢了,,
 楼主| 发表于 2010-2-26 02:25:15 | 显示全部楼层
如果还有啥文章自己不方便下载,可以把名字告诉我,我试试帮着下载
发表于 2010-3-5 18:18:39 | 显示全部楼层
thanks
发表于 2010-3-29 10:46:02 | 显示全部楼层
我要下载
发表于 2010-3-31 15:41:11 | 显示全部楼层
好东东
发表于 2010-4-11 14:15:15 | 显示全部楼层
感谢楼主的分享
发表于 2010-4-11 16:11:05 | 显示全部楼层
路过,关注一下!
发表于 2010-5-5 12:07:50 | 显示全部楼层
谢谢楼主
发表于 2010-5-7 18:14:47 | 显示全部楼层
thanks for sharing
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-11 07:13 , Processed in 0.021581 second(s), 8 queries , Gzip On, Redis On.
