查看: 22044|回复: 65
[资料] IEEE --Low-Voltage CMOS Analog Bootstrapped Switch
发表于 2010-2-21 15:13:24 | 显示全部楼层 |阅读模式
Low-Voltage CMOS Analog Bootstrapped Switch For
Sample-and-Hold Circuit: Design and Chip Characterization
This paper presents the design and characterization
of a sample-and-hold circuit based on a novel implementation
of the bootstrapped low-voltage analog CMOS switch. The
heart of this circuit is a new low-voltage and low-stress CMOS
clock voltage doubler. Through the use of a dummy switch, the
charge injection induced by the bootstrapped switch is greatly
reduced, resulting in improved sample-and-hold accuracy.
Experimental results in a 0.18 μm digital CMOS process show
that a resolution greater than 10 bits can be obtained with a 1.0
V supply voltage. Circuit operation is also possible for supply
voltages close to transistor threshold (e.g., 0.65 V).
Low-Voltage CMOS Analog Bootstrapped Switch For.pdf
242.07 KB, 下载次数: 1074 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-2-25 02:35:23 | 显示全部楼层
thank you..
发表于 2010-2-26 18:12:19 | 显示全部楼层
thank you..
发表于 2010-3-4 23:12:17 | 显示全部楼层
thansk a lot~~~
发表于 2010-3-4 23:15:24 | 显示全部楼层
thans ka lto~~
发表于 2010-3-5 00:12:36 | 显示全部楼层
THANKS
发表于 2010-3-9 11:07:54 | 显示全部楼层
dfaffdasfdsa
发表于 2010-3-15 16:34:06 | 显示全部楼层
好东西
发表于 2010-3-18 20:06:36 | 显示全部楼层
謝謝無私的分享
发表于 2010-3-18 20:37:33 | 显示全部楼层
xiexie a ,hehe ,taihao le
GMT+8, 2025-12-19 17:11 , Processed in 0.027014 second(s), 7 queries , Gzip On, Redis On.
