查看: 8220|回复: 13
A Verilog HDL Test Bench Primer Application Note
发表于 2006-8-24 00:10:17 | 显示全部楼层 |阅读模式
As digital systems become more complex, it becomes increasingly important to verify the
functionality of a design before implementing it in a system. Hardware Descriptions
Languages (HDL’s) have become extremely popular because the same language can be
used by engineers for both designing and testing CPLD’s and FPGA’s. The two most
common HDL’s are Verilog and VHDL. This document focuses on using Verilog HDL
to test digital systems, by giving the designer a handful of simulation techniques that can
be used on the majority of digital applications.
A Verilog HDL Test Bench Primer.pdf
63.94 KB, 下载次数: 53 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-9-3 19:47:42 | 显示全部楼层
写得太简单了
发表于 2006-11-23 13:54:36 | 显示全部楼层
没有看过,不一置评。
不过,如果真得很简单,或者在一般的教科书中都找得到的冬冬,还是不要上载为宜。
发表于 2006-11-25 00:23:28 | 显示全部楼层
Thanks !!
发表于 2006-11-25 01:13:29 | 显示全部楼层
搂住辛苦了。
发表于 2006-11-30 13:46:34 | 显示全部楼层
好好学习吧
发表于 2006-12-2 12:56:08 | 显示全部楼层
ddddddddddddddddddddddddddddddddddd
发表于 2007-1-8 23:45:16 | 显示全部楼层
是啊 好像很小唉
发表于 2007-6-3 09:32:08 | 显示全部楼层
好啊!谢谢了!
发表于 2007-10-1 08:43:49 | 显示全部楼层
看看是否真的很简单
GMT+8, 2025-12-27 18:26 , Processed in 0.033217 second(s), 7 queries , Gzip On, Redis On.
