查看: 3985|回复: 5
[求助] IAR for MSP430 4.20 比 3.41多了什么功能?
发表于 2010-2-8 00:19:31 | 显示全部楼层 |阅读模式
是不是3.41更稳定?
发表于 2010-5-26 08:43:23 | 显示全部楼层
同 问  需要解答
发表于 2010-5-26 08:46:31 | 显示全部楼层
没人顶呀
发表于 2010-6-11 14:00:26 | 显示全部楼层
其实我也想问问 正式版 和 评估板的区别
发表于 2010-9-15 13:53:02 | 显示全部楼层
The following product packages are available:
Standard edition
The standard edition has all features implemented.
Limited edition
The limited edition is a version of IAR Embedded Workbench without a debugger. Limitations:
The IAR C-SPY debugger is not available.
MISRA C is not available.
BaseLine edition information
The BaseLine edition is a special low-priced version of IAR Embedded Workbench. It has limitations both in performance and in the service and support that is provided. Limitations:
The code size limit of the MSP430 IAR Baseline C/C++ Compiler is set to 16 Kbytes.
The IAR Assembler delivered is the full version without any restrictions.
The IAR XLINK Linker will link a maximum of 16 Kbytes originating from C souce code, but an unlimited amount of code originating from assembly code.
The IAR BaseLine C-SPY Simulator will read a maximum of 16 Kbytes originating from C souce code, but an unlimited amount of code originating from assembly code.
KickStart edition
The KickStart edition is a special starter-kit/evaluation version of IAR Embedded Workbench with limitations both in code size and in the service and support that is provided. Limitations:
The code size limit of the MSP430 IAR KickStart C/C++ Compiler is set to 4 Kbytes for traditional MSP430 devices and 8 Kbytes for MSP430X devices.
The IAR XLINK Linker will link a maximum of 4 Kbytes originating from C souce code for traditional MSP430 devices and 8 Kbytes for MSP430X devices, but an unlimited amount of code originating from assembly code.
The IAR KickStart C-SPY Simulator will read a maximum of 4 Kbytes originating from C code for traditional MSP430 devices and 8 Kbytes for MSP430X devices but is unlimited in the amount of assembly code read.
The runtime library source code is not included.
Evaluation edition
The Evaluation edition is a time-limited evaluation version that you will be able to run for 30 days. Limitations:
Will expire 30 days after generation of the evaluation key.
The runtime library source code is not available.
发表于 2011-5-11 08:48:54 | 显示全部楼层
Thanks.
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-11 04:17 , Processed in 0.015026 second(s), 4 queries , Gzip On, Redis On.
