查看: 3130|回复: 1
Faster Power/Ground Grid Closure with In-Design Rail Analysis
发表于 2010-1-28 19:57:21 | 显示全部楼层 |阅读模式
http://www.techonline.com/learning/webinar/218100327?queryText=synopsys
On-Demand Webinar
Overview:
Please join our free 45-minute webinar (plus a Q&A) to learn howyou can use in-design rail analysis to accelerate the path to finaldesign closure.
Finding power grid issues in the late stages of physical implementationcan lead to painful rip-up and repair iterations. In-design railanalysis with PrimeRail provides a push button flow inside IC Compilerthat enables you to analyze and identify potential problems earlierwhere changes are less intrusive. Join our experts to learn how you canuse in-design rail analysis to analyze and debug voltage drop, power upand electromigration (EM) effects as early as placement, acceleratingthe path to final design closure.
发表于 2022-5-22 02:07:49 | 显示全部楼层
where I can find the material
GMT+8, 2025-12-25 11:21 , Processed in 0.019468 second(s), 6 queries , Gzip On, Redis On.
