查看: 3291|回复: 10
[资料] Digital Design (Verilog): An Embedded Systems Approach Using Verilog
发表于 2010-1-20 13:57:31 | 显示全部楼层 |阅读模式
By Peter J. Ashenden
Publisher: Morgan Kaufmann
Number Of Pages: 584
Publication Date: 2007-09-14
ISBN-10 / ASIN: 0123695279
ISBN-13 / EAN: 9780123695277
Binding: Paperback
DigitalDesign: An Embedded Systems Approach Using Verilog provides afoundation in digital design for students in computer engineering,electrical engineering and computer science courses. It takes anup-to-date and modern approach of presenting digital logic design as anactivity in a larger systems design context.
Rather than focuson aspects of digital design that have little relevance in a realisticdesign context, this book concentrates on modern and evolving knowledgeand design skills. Hardware description language (HDL)-based design andverification is emphasized--Verilog examples are used extensivelythroughout. By treating digital logic as part of embedded systemsdesign, this book provides an understanding of the hardware needed inthe analysis and design of systems comprising both hardware andsoftware components.
Includes a Web site with links to vendor tools, labs and tutorials.
Presents digital logic design as an activity in a larger systems design context.
Featuresextensive use of Verilog examples to demonstrate HDL usage at theabstract behavioural level and register transfer level, as well as forlow-level verification and verification environments.
Includes worked examples throughout to enhance the reader's understanding and retention of the material.
CompanionWeb site includes links to CAD tools for FPGA design from Synplicity,Mentor Graphics, and Xilinx, Verilog source code for all the examplesin the book, lecture slides, laboratory projects, and solutions toexercises.
Summary: thorough coverage
Rating: 4
Ashendenteaches digital design from scratch. The prerequisites are minimal, asperhaps you might be glad to know. While many readers might come fromelectrical engineering, you don't need much analog circuit experience.Digital circuitry treats the transistors and other components at a verysimple but useful level of understanding. In other words, if yourbackground is pure computer science, and no hardware, the book shouldstill work for you.
The flow of teaching is fairly standard.Start with Boolean algebra and the simplest circuits that implementthese. Then build up from there. [How else can you teach this stuff?]The coverage is thorough, for a first text on the subject. The onlyslight quirk is that the problems tend to be a little too simple. It'snecessary to have easy questions. But some harder problems might alsohelp.
The narrative also uses Verilog as the HardwareDescription Language. The de facto standard for many, and well worthlearning if you're serious about pursing a career in this field.
http://rapidshare.com/files/107191203/0123695279.rar
http://mihd.net/6b4wq8j/
http://www.filefactory.com/file/2ac028/
发表于 2010-1-20 15:55:03 | 显示全部楼层
thanks
发表于 2010-1-21 00:25:24 | 显示全部楼层
It's good thanks
发表于 2010-1-21 01:07:29 | 显示全部楼层
good book,thx
发表于 2010-1-21 01:10:58 | 显示全部楼层
good data,
thx
发表于 2010-1-21 08:48:57 | 显示全部楼层
Thanks a lot.
发表于 2010-1-21 08:58:55 | 显示全部楼层
不错不错
发表于 2010-1-21 11:55:45 | 显示全部楼层
goodjob
发表于 2010-1-21 12:20:45 | 显示全部楼层
发 重复 了,以前有 人 上 载过!
发表于 2010-1-21 22:34:16 | 显示全部楼层
thanks!
GMT+8, 2025-12-23 04:54 , Processed in 0.024101 second(s), 5 queries , Gzip On, Redis On.
