查看: 3424|回复: 1
请问怎么样在cpld中使用全局时钟?
发表于 2006-8-17 22:19:16 | 显示全部楼层 |阅读模式
在cpld中使用全局时钟,看介绍要使用BUFG的。在Verilog HDL中如下定义:
    input clk_in;
    wire clk_tmp,clk_buf;
    IBUF GBUFa(.O(clk_tmp),.I(clk_in));
    BUFG GBUFb(.O(clk_buf),.I(clk_tmp));
在assign package pins里把clk_in定义到GCLK3上了,但在XST时还是报错:
Checking timing specifications ...
Checking expanded design ...
ERROR:NgdBuild:455 - logical net 'clk_tmp' has multiple driver(s):
     pin O on block GBUFa with type IBUF,
     pin PAD on block clk_tmp with type PAD
WARNING:NgdBuild:463 - input pad net 'clk_tmp' has an illegal input buffer
ERROR:NgdBuild:925 - input net 'clk_tmp' is connected to the incorrect side of
   buffer(s):
求教,BUFG的正确用法,谢谢各位了。
 楼主| 发表于 2006-8-20 19:54:11 | 显示全部楼层
哪位高手指点一下,谢谢
GMT+8, 2025-12-17 00:06 , Processed in 0.027825 second(s), 7 queries , Gzip On, Redis On.
