查看: 3826|回复: 8
Can we install IC613 HOTfix directly without base??
发表于 2010-1-7 04:19:47 | 显示全部楼层 |阅读模式
Can we install IC613 HOTfix directly without install base first??
发表于 2010-1-7 09:04:14 | 显示全部楼层
No, you need IC610 base file or have a installation of it.
发表于 2010-2-3 10:01:18 | 显示全部楼层
thank you very much
发表于 2010-8-11 20:25:30 | 显示全部楼层
what is base file , explain in details
发表于 2010-8-11 22:40:21 | 显示全部楼层
发表于 2010-8-12 19:04:32 | 显示全部楼层
can the 610 lic use for 613 ?
发表于 2011-6-27 13:37:42 | 显示全部楼层
没有base能直接安装ic614吗? 请牛人帮助回答
发表于 2012-10-24 16:54:17 | 显示全部楼层
发表于 2015-11-4 15:41:15 | 显示全部楼层
thanks a lot !
GMT+8, 2025-12-19 02:27 , Processed in 0.023512 second(s), 7 queries , Gzip On, Redis On.
