查看: 1799|回复: 2
[原创] the paper
发表于 2010-1-6 14:12:04 | 显示全部楼层 |阅读模式
谁有这篇paper,共享下,谢谢。
Systematic Design for Optimization of High-Resolution Pipelined ADCs,
ABSTRACT
Pipelining is the promising approach to implement high-speed medium-to-high resolution analog-to-digital converters with minimum power consumption. In this paper, the most important specifications of a pipelined ADC including the signal-to-noise-and-distortion ratio and spurious-free dynamic range as well as the total current consumption of the converter are presented in closed-form equations and an optimization methodology for design of pipelined ADCs is suggested. Simulation results confirming the effectiveness of the methodology are presented.
发表于 2010-1-6 14:24:12 | 显示全部楼层
1# hardmany 楼主看看是这个不?
systematic design for optimization of high-resolution pipelined ADCs.pdf
108.98 KB, 下载次数: 13 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2010-1-6 21:04:44 | 显示全部楼层
下来看看呢
GMT+8, 2025-9-13 15:43 , Processed in 0.654883 second(s), 6 queries , Gzip On, Redis On.
