CST Studio Suite 2009 + Servise Pack 6. In the complete training material
CST Studio Suite 2009 + Service Pack 6. In the complete training material | 4.1GB
CST Studio Suite 2009 - CAD for engineers and designers needed to calculate antenna environments, structures under the influence of EM waves.
Consisting of the following versions, additions and applications:
- CST Studio Suite 2009
- Service Pack 6 for CST Studio Suite 2009
Year: 2009
Version: 2009
Developer: CST - Computer Simulation Technology
Platform: Windows / Linux
Compatibility with Vista: unknown
Language: English only
Tabletka: Present
Description: CST Studio Suite 2009 - CAD for engineers and designers needed to calculate antenna environments, structures under the influence of EM waves.
Extras. Information:
CST STUDIO SUITE ™
Electromagnetic simulation software CST STUDIO SUITE ™ is the culmination of many years of research and development in the most efficient and accurate computational solutions to electromagnetic design. It includes the following modules:
CST Design Environment ™ (CST DE) is a point of access to the CST STUDIO SUITE ™
CST Microwave-Studio ® (CST MWS) is a specialist tool for fast and accurate 3D EM simulation of high frequency problems. Along with a wide range of applications, CST Microwave-Studio ® offers considerable product to market advantages: shorter development cycles - Virtual prototyping before physical trials - instead of the optimization experiments.
CST DESIGN STUDIO ™ (CST DS) provides a powerful environment for the design, which results from different simulators can be combined and analyzed.
CST EM STUDIO ™ (CST EMS) is an easy to use tool for analysis and design of static structures and low frequency.
CST PARTICLE STUDIO ™ (CST PS) for the simulation of freely moving charged particles as in electron guns, cathode ray tubes, ...
Servise Pack 6 for CST Studio Suite 2009
Year: 2009
Version: 2009.06 on April 28, 2009, Mr.
Developer: CST Gmbh
Platform: Windows 2000 | XP x86/x64 | Vista | Linux
Tabletka: Present
Description: What is included in the service pack (from the program documentation):
CST MICROWAVE STUDIO
1. Environment
Fixed recognition of the latest processors from AMD
Fixed problem with parallel under Linux
Fixed problem importing curves with additional markers
Resolved update handling for table info in the navigation tree.
2. Distributed computing
Loses its connection with the Main Controller when closing windows with charts
DC server is not run for IP-addresses 169.xxx
Fixed resource leaks in MainController
Nelder-Mead stops after max evaluations also with distributed computing.
3. Modeler / Display structure / Import items
Fixed editing in a window "Transformation"
Fixed problem with color by default when importing multi-layer structures Gerber
Now you can use a tab in the files. Mdf for compatibility with older versions of ADS
Fixed a problem on 64-bit systems when selecting FSS project templates
4. Rectangular (hexahedral) grid
Fixed handling TST grid cells on the upper boundary for some boundary conditions.
Improved stability tool «edge refinement» using subgrid.
Improved definition of ports in the presence of symmetry planes
5. Transient Solver / Eigenmode Solver
New. Transient Solver for the opportunity to use the hardware accelerator A40 and D40
Solve the problem installing hardware acceleration. We solve the problem of errors license for hardware acceleration
Eigenmode Solver added to the solution of an alternative system of equations, using less memory
6. Frequency Domain (FD) Solvers
When specifying an asymmetric ports were considered wrong impedances of transmission lines for the modes of non-asymmetric
Monitors the magnetic field and, accordingly, displays the fields that depend on them, were considered wrong when excited discrete face port.
CST EM STUDIO / CST PARTICLE STUDIO Solvers
We solve the problem of the use of materials with nonlinear properties in the problems of electrostatics and Particle Solver
Improved calculation of the magnetic fields near the cathode
Post Processing / Fields / Farfield
Adjusted values are displayed for the far zone in one-dimensional representation
Fixed problem when running the corresponding renormalization VBA commands
Fixed loading 3D results for the project, which is used to define the structure of imports of EDA
Corrected assignment of coordinates using the option «draw in volume»
CST DESIGN STUDIO / CST PCB STUDIO / CST CABLE STUDIO
Solve the problem of extrapolation with parallel computations
Improved message that appears when you try to calculate the circuit with open ports
Fixed problem importing blocks of Microwave Studio version 2008
Fixed problem with empty waveguide block
Fixed problem with generalized impedance of the transmission line
Increased threshold for determining the instability from 100 kW to 1 GW
We solve the problem of access to blocks Simlab, containing controlled sources
Fixed issue in connectivity analysis for PEEC terminal grouping.
Fixed an analysis of the key ON / OFF in SPICE-models
For Simlab given initial conditions defining the constant voltage
Introduced hysteresis loop for SPICE switches in accordance with the state of the parameter ON / OFF
We solve the problem of models containing only a single block of S-parameters
Fixed a rare problem with interpolation of some blocks, based on the 2D EM
Fixed problem with probes attached to the blocks Design Studio
Solve the problem of exporting the geometry of microstrip lines in the Microwave Studio
Fixed problem with semiconductor devices using the default settings
Homepage
http://www.cst.com/
Download:
http://rapidshare.com/files/326818759/CST_STUDIO_SUITE_2009.part01.rar
http://rapidshare.com/files/326816723/CST_STUDIO_SUITE_2009.part02.rar
http://rapidshare.com/files/326818120/CST_STUDIO_SUITE_2009.part03.rar
http://rapidshare.com/files/326818266/CST_STUDIO_SUITE_2009.part04.rar
http://rapidshare.com/files/326818122/CST_STUDIO_SUITE_2009.part05.rar
http://rapidshare.com/files/326819033/CST_STUDIO_SUITE_2009.part06.rar
http://rapidshare.com/files/326816916/CST_STUDIO_SUITE_2009.part07.rar
http://rapidshare.com/files/326817383/CST_STUDIO_SUITE_2009.part08.rar
http://rapidshare.com/files/326818362/CST_STUDIO_SUITE_2009.part09.rar
http://rapidshare.com/files/326818257/CST_STUDIO_SUITE_2009.part10.rar
http://rapidshare.com/files/326817702/CST_STUDIO_SUITE_2009.part11.rar
http://rapidshare.com/files/326817619/CST_STUDIO_SUITE_2009.part12.rar
http://rapidshare.com/files/326818288/CST_STUDIO_SUITE_2009.part13.rar
http://rapidshare.com/files/326816978/CST_STUDIO_SUITE_2009.part14.rar
http://rapidshare.com/files/326817948/CST_STUDIO_SUITE_2009.part15.rar
http://rapidshare.com/files/326817727/CST_STUDIO_SUITE_2009.part16.rar
http://rapidshare.com/files/326818546/CST_STUDIO_SUITE_2009.part17.rar
http://rapidshare.com/files/326818142/CST_STUDIO_SUITE_2009.part18.rar
http://rapidshare.com/files/326817028/CST_STUDIO_SUITE_2009.part19.rar
http://rapidshare.com/files/326818242/CST_STUDIO_SUITE_2009.part20.rar
http://rapidshare.com/files/326817435/CST_STUDIO_SUITE_2009.part21.rar
http://rapidshare.com/files/326817313/CST_STUDIO_SUITE_2009.part22.rar
http://rapidshare.com/files/326819153/CST_STUDIO_SUITE_2009.part23.rar
http://rapidshare.com/files/326818136/CST_STUDIO_SUITE_2009.part24.rar
http://rapidshare.com/files/326817844/CST_STUDIO_SUITE_2009.part25.rar
http://rapidshare.com/files/326818525/CST_STUDIO_SUITE_2009.part26.rar
http://rapidshare.com/files/326817894/CST_STUDIO_SUITE_2009.part27.rar
http://rapidshare.com/files/326816990/CST_STUDIO_SUITE_2009.part28.rar
http://rapidshare.com/files/326818193/CST_STUDIO_SUITE_2009.part29.rar
http://rapidshare.com/files/326818707/CST_STUDIO_SUITE_2009.part30.rar
http://rapidshare.com/files/326816680/CST_STUDIO_SUITE_2009.part31.rar
http://rapidshare.com/files/326818396/CST_STUDIO_SUITE_2009.part32.rar
http://rapidshare.com/files/326818476/CST_STUDIO_SUITE_2009.part33.rar
http://rapidshare.com/files/326819131/CST_STUDIO_SUITE_2009.part34.rar
http://rapidshare.com/files/326817018/CST_STUDIO_SUITE_2009.part35.rar
http://rapidshare.com/files/326816174/CST_STUDIO_SUITE_2009.part36.rar
http://rapidshare.com/files/326819017/CST_STUDIO_SUITE_2009.part37.rar
http://rapidshare.com/files/326818836/CST_STUDIO_SUITE_2009.part38.rar
http://rapidshare.com/files/326818744/CST_STUDIO_SUITE_2009.part39.rar
http://rapidshare.com/files/326818783/CST_STUDIO_SUITE_2009.part40.rar
http://rapidshare.com/files/326817710/CST_STUDIO_SUITE_2009.part41.rar
Servise Pack 6
http://rapidshare.com/files/326816814/SP6.rar |
crack.rar
23.85 KB, 下载次数: 63
, 下载积分:
资产 -2 信元, 下载支出 2 信元
