查看: 13160|回复: 9
[求助] 请教一个calibre LVS的问题。
发表于 2009-12-28 15:31:52 | 显示全部楼层 |阅读模式
小弟最近在学版图,在candece下做的,是做了一个简单的反向器,电路图和版图为:
利用calibre 做LVS结果为:
没有看到笑脸 ,可见有错误的,报告里面有这下面两个错误
Error:
Different numbers of ports (see below).
Power net missing in layout. Ground net missing in layout.
我在版图里面画了四个pin,分别为vdd gnd 还有输入输出 A ,OUT
端口都是对着的怎么会出现不同的ports,还有power 和Ground是怎么回事?
用candence提取的网表为:
* auCdl Netlist:
* Library Name:
test
* Top Cell Name: inv
* View Name:
schematic
* Netlisted on:
Dec 28 01:17:53 2009
*.BIPOLAR
*.RESI = 2000
*.RESVAL
*.CAPVAL
*.DIOPERI
*.DIOAREA
*.EQUATION
*.EQUIV nmos_3p3=NM
*.EQUIV pmos_3p3=PM
*.EQUIV npolyf_u_1k=YAK
*.EQUIV PIP=CP
*.EQUIV VPNP_5x5=BV
*.SCALE METER
*.MEGA
.PARAM
* Library Name: test
* Cell Name:
inv
* View Name:
schematic
.SUBCKT inv A OUT gnd vdd
*.PININFO A:I OUT:O gnd:B vdd:B
MNM0 OUT A gnd gnd NM W=2u L=1u M=1.0
MPM0 OUT A vdd vdd PM W=4u L=1u M=1.0
.ENDS
请懂的朋友给指点下小弟,刚开始学画版图,按教程做了一个,请给指点下错误,
不胜感激---
下面我把报告附上
##C A L I B R E
          S Y S T E M
######       L V SR E P O R T
REPORT FILE NAME:inv.lvs.report
LAYOUT NAME:inv.sp ('inv')
SOURCE NAME:netlist ('inv')
RULE FILE:/home/eda/_chrt035rf.sg.lvs.cal_
RULE FILE TITLE:
Mentor Calibre LVS Runset for Chartered 0.35um Analog/RF Single Gate (3.3V) Process
CREATION TIME:Mon Dec 28 01:54:26 2009
CURRENT DIRECTORY:/home/eda
USER NAME:eda
CALIBRE VERSION:v2006.1_25.26
Thu Apr
6 13:20:44 PDT 2006
OVERALL COMPARISON RESULTS
# #####NOT COMPARED
Error:
       Different numbers of ports.
Error:
       Power or ground net missing.
**************************************************************************************************************CELLSUMMARY
Result                   Layout     Source
NOT COMPARED   inv      inv
CELL COMPARISON RESULTS ( TOP LEVEL )
##NOT COMPARED
Error:
Error:
LAYOUT CELL NAME:inv
SOURCE CELL NAME:inv
INITIAL NUMBERS OF OBJECTS
Layout
Source   Component Type
Ports:     0          4*
Nets:      4            4
Instances:1           1      MN (4 pins)
               1           1      MP (4 pins)
total Inst: 2             2
NUMBERS OF OBJECTS AFTER TRANSFORMATION
          Layout    Source     Component Type
Ports:    0           4
Nets:    4            4
Instances:1         0          MN (4 pins)
               1         0          MP (4 pins)
               0           1       INV (2 pins): output input
Total Inst: 2            1
* = Number of objects in layout different from number in source.
SUMMARY
Total CPU Time:
0 sec
Total Elapsed Time:
1 sec
 楼主| 发表于 2009-12-28 16:20:23 | 显示全部楼层
、自己先顶下,别下沉了
 楼主| 发表于 2009-12-28 17:39:26 | 显示全部楼层
哈哈 ,师兄给解决了,是pin的层选择错了
发表于 2009-12-29 18:55:03 | 显示全部楼层
OK!OK!
发表于 2009-12-31 02:46:18 | 显示全部楼层
i think you power lebal is loss
发表于 2010-8-5 15:20:59 | 显示全部楼层
图呢?
发表于 2010-9-1 15:27:14 | 显示全部楼层
pin名字要打标签放在相应的层,而且标签还要用端口对应的图层标。
回复 支持 0 反对 1
发表于 2010-9-2 15:25:34 | 显示全部楼层
呵呵,做LVS首先要看Port个数是否对应的!
发表于 2012-2-22 19:37:17 | 显示全部楼层
你好,请问做LVS的那个rule要怎么改啊?
发表于 2015-7-3 17:28:31 | 显示全部楼层
回复 3# ppppchang
    请问具体是什么情况呢?怎么解决啊?
GMT+8, 2025-10-4 06:48 , Processed in 0.022807 second(s), 5 queries , Gzip On, Redis On.
