查看: 4951|回复: 8
[资料] 最新博士论文:A Multi-Bit Hybrid DSM over Full-Scale Range without Feedback DEM
发表于 2009-12-21 03:23:20 | 显示全部楼层 |阅读模式
Un-Ku Moon 09年的新毕业博士生.是连续时间delta-sigma的论文.
osu10.pdf
1.58 MB, 下载次数: 157 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-12-21 12:26:21 | 显示全部楼层
Evolution of the mobile communication standards and proliferation of hand-
held devices mandate stringent Analog-to-Digital Converter (ADC) speci¯cations.
Among various ADCs, a ¢§ ADC is best known as a power-e±cient ADC when
more than 12b is required. However, a conventional discrete-time (DT) ¢§ Modu-
lator (¢§M) is inadequate for low-power wideband applications due to the opamp
settling requirement. Alternatively, a continuous-time (CT) ¢§M can be used
to decrease power consumption but has its own disadvantages such as clock jitter
sensitivity, RC time constant variation, and excess loop delay.
The wideband modulators are often implemented as single-loop high-order
modulators in a deep submicron process. The high-order modulator typically has a
quantizer overloading problem as the input signal approaches to a full-scale range.
A pole-optimization method can be used to extend the linear input range but it
inevitably decreases signal to quantization noise ratio. This causes power penalty
since it limits the maximum input power available.
发表于 2010-1-21 03:15:13 | 显示全部楼层
thank you
发表于 2010-2-27 20:20:57 | 显示全部楼层
thansk alto~~
发表于 2010-3-4 23:37:27 | 显示全部楼层
thansk al aot~~
发表于 2010-3-5 07:39:40 | 显示全部楼层
ding kanka
发表于 2010-3-5 08:29:05 | 显示全部楼层
做的东西一般般,不过结构挺新颖
发表于 2019-12-13 12:30:04 | 显示全部楼层
谢谢
发表于 2020-6-24 00:46:17 | 显示全部楼层
谢谢
GMT+8, 2025-12-26 01:10 , Processed in 0.023862 second(s), 7 queries , Gzip On, Redis On.
