查看: 4610|回复: 1
[求助] 请问有没有用过ALTASMI_PARALLEL这个IP的大侠?
发表于 2009-12-16 09:26:36 | 显示全部楼层 |阅读模式
在该IP的user guide文档里看到:
The megafunction uses the clkin signal to feed the EPCS device (DCLK)and to perform internal processing. For a read operation, the clkin signal can toggle at a maximum frequency of 20 MHz. For a fast read operation, the frequency of the clkin signal can toggle at a maximum of 25 MHz.
在Cyclone II Device Handbook里看到:
Cyclone II devices use an internal oscillator to generate DCLK. Using the
MSEL[] pins, you can select either a 20- or 40-MHz oscillator.
从IP的文档里看到的是DCLK最大只能25M。可是从handbook里看到的是可以达到40M...
请问是我理解错误还是文档写的有问题?
发表于 2017-4-6 23:19:48 | 显示全部楼层
呵呵,学习中
GMT+8, 2025-12-29 09:04 , Processed in 0.012134 second(s), 3 queries , Gzip On, Redis On.
