查看: 3268|回复: 2
tmgui help?
发表于 2009-12-15 18:24:55 | 显示全部楼层 |阅读模式
It has been a long time since I ran Tetramax.
When I run the command-line version of Tetramax (tmax32), it starts upjust fine (it's able to find our license-server and checkout alicense.) However, it I try to use the GUI-version (tmaxgui), the GUIcomes up, but none of the buttons work. Basically, the program windowappears, but it's "dead."
Is this a common problem? Do I need to set some specialenvironment-vars to get tmaxgui running? (I'm running on RHEL 4 Update4, 64-bit.)
 楼主| 发表于 2009-12-16 08:37:42 | 显示全部楼层
自己顶一下
发表于 2009-12-18 22:18:00 | 显示全部楼层
Thanks
GMT+8, 2025-12-28 11:43 , Processed in 0.015362 second(s), 5 queries , Gzip On, Redis On.
