查看: 11910|回复: 41
Bandwidth Estimation Techniques(By Thomas Lee)
发表于 2006-8-9 08:54:41 | 显示全部楼层 |阅读模式
Finding the –3 dB bandwidth of an arbitrary linear network can be a difficult problem in
general.
Two such approximate methods are open- and short-circuit time constants. The former
provides an estimate of the high-frequency rolloff while the latter yields an estimate of the
low-frequency rolloff point. These methods are valuable because they identify which elements
are responsible for the bandwidth limitation.
Bandwidth Estimation Techniques.pdf
1.31 MB, 下载次数: 232 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2006-12-24 16:29:26 | 显示全部楼层
发表于 2006-12-24 16:30:31 | 显示全部楼层
发表于 2007-1-15 10:55:15 | 显示全部楼层
so sort techinque in determine the bandwidth , nice article
发表于 2007-1-19 10:37:59 | 显示全部楼层
回复 #1 STMicro 的帖子
很有参考价值!!!
发表于 2007-1-25 12:13:27 | 显示全部楼层
很经典,谢谢了
发表于 2007-1-25 12:47:16 | 显示全部楼层
谢谢呀,下了
发表于 2007-1-25 15:09:48 | 显示全部楼层
thanks !up!up!up!
发表于 2007-1-25 15:31:29 | 显示全部楼层
35页的东东,还算详细的介绍!不错!
发表于 2007-1-25 15:34:15 | 显示全部楼层
Introduction
general. Consider, for example, the standard recipe for computing bandwidth:
1) Derive the input-output transfer function (using node equations, for example)
2) Set s = jw;
3) Find the magnitude of the resulting expression;
4) Set the magnitude = 1/ of the “midband” value; and
5) Solve for w
It doesn't take a great deal of insight to recognize that explicit computation (by hand) of
the –3 dB bandwidth using this method is generally impractical for all but the simplest
systems. In particular, the order of the denominator polynomial obtained in step 1 above is
equal to the number of poles (natural frequencies), which in turn equals the number of
degrees of freedom (measured, say, by the number of initial conditions one may independently
specify), which in turn equals the number of independent energy storage elements
(e.g., L or C), which in turn can be as large as the number of energy storage elements
(phew!). Thus, a network with n capacitors might require the equivalent of finding the
roots of an nth-order polynomial. If n exceeds just four, no algebraic closed form solution
exists. Even if n = 2, it might be labor-intensive to obtain the final numerical result.
Now, machine computation is cheap and getting cheaper all the time, so perhaps the analysis
of networks doesn’t present much of a problem. However, we are interested in developing
design insight so that if a simulator tells us that there is a problem, we have some idea
of what to do about it. We therefore seek methods that are reasonably simple to apply, yet
conveys the desired insight, even if it yields answers that might be approximate. Simulators
can then be used to provide final quantitative verification.
are responsible for the bandwidth limitation. This information alone is often sufficient
to suggest what modifications should be tried next.
2
GMT+8, 2025-12-25 14:16 , Processed in 0.025079 second(s), 8 queries , Gzip On, Redis On.
