楼主: 矽阳
Agilent goldengate 4.3.8
发表于 2010-5-11 13:05:07 | 显示全部楼层
where is crack
can upload them
发表于 2010-5-11 13:09:30 | 显示全部楼层
where is crack
can upload them
发表于 2010-5-15 22:44:11 | 显示全部楼层
哪位有unix下的goldengate?带licence?
发表于 2010-5-27 23:12:26 | 显示全部楼层
great! thanks
发表于 2010-5-27 23:20:10 | 显示全部楼层
license?
发表于 2010-5-31 09:52:59 | 显示全部楼层
thank you
发表于 2010-5-31 12:20:50 | 显示全部楼层
10# abaiyi 谢谢楼主!
发表于 2010-5-31 12:25:26 | 显示全部楼层
37# ased2 thanks
发表于 2010-5-31 12:33:01 | 显示全部楼层
5# st5900 thanks
发表于 2010-7-15 10:45:18 | 显示全部楼层
Conversion between field strength and propagation loss
The field strength, E1546 directly predicted by Rec. ITU-R P.1546-3, assumes a transmitter ERP = 0 dBkW; E1546 is expressed in units of dBV/m. For an arbitrary ERPdBkW, the predicted field strength, E1546, expressed in units of dBV/m, is
                E1546 = E1546 + ERPdBkW
The propagation loss (‘LOSS’) predicted by the Hata model is expressed in dB (i.e., independent of transmitter power).
The relationship between predicted field strength, E1546 (i.e., for ERP = 0 dBkW), and the predicted propagation loss, LOSSdB, for a given frequency (fMHz) measured in MHz, is the following:
                E1546 = 139.3 + 20 log fMHz – LossdB;
                LossdB = 139.3 + 20 log fMHz – E1546.
For any given ERPdBkW, the corresponding relationship between E1546 and the predicted propagation loss, for a given frequency (fMHz), is the following:
                E1546 = 139.3 + 20 log fMHz – LossdB + ERPdBkW;
                LossdB = 139.3 + 20 log fMHz – E1546 + ERPdBkW.
GMT+8, 2025-12-23 22:15 , Processed in 0.039687 second(s), 3 queries , Gzip On, Redis On.
