查看: 9074|回复: 10
求助:spice explorer 2006 安装
发表于 2009-11-15 23:56:39 | 显示全部楼层 |阅读模式
我想在linux装一个spice explorer,从EETOP的资源里我发现2006版的license还挺多,所以就选择了它(如果有朋友其他版本安装成功的请推荐给我,谢谢)。我将下载的license.dat内容根据需求修改了一下。
原本:
SERVER elena ANY 27000 DAEMON sandwork sandwork FEATURE spice_explorer sandwork 2010.12 01-dec-2010 uncounted 0D025F6BD0D4BFCB7197 HOSTID=ANY \ SIGN=DA8EAEBE90322F34 FEATURE sx_cdslink sandwork 2010.12 01-dec-2010 uncounted ED225FABDEECB988AC17 HOSTID=ANY \ SIGN=2D1A420C42B89818 FEATURE sx_chip sandwork 2010.12 01-dec-2010 uncounted ADC2CF6BC783E3D0F10C HOSTID=ANY \ SIGN=E2864CDA64EA383A FEATURE sx_daiclink sandwork 2010.12 01-dec-2010 uncounted FD821FFBAA4DA443D920 HOSTID=ANY \ SIGN=95A44F82B1FC792C FEATURE sx_drc sandwork 2010.12 01-dec-2010 uncounted 0DF24F5B026CF1CEEDF4 HOSTID=ANY \ SIGN=438A4F6CEAE41058 FEATURE sx_wva sandwork 2010.12 01-dec-2010 uncounted 1D12FF8B0450D1BDEFF2 HOSTID=ANY \ SIGN=F868E802B16CC48C
修改后:
SERVER localhost.localdomain 000FEA008949  27000DAEMON sandwork /synopsys/sx2006/bin/sandworkFEATURE spice_explorer sandwork 2010.12 01-dec-2010 uncounted 0D025F6BD0D4BFCB7197 HOSTID=ANY \SIGN=DA8EAEBE90322F34FEATURE sx_cdslink sandwork 2010.12 01-dec-2010 uncounted ED225FABDEECB988AC17 HOSTID=ANY \SIGN=2D1A420C42B89818FEATURE sx_chip sandwork 2010.12 01-dec-2010 uncounted ADC2CF6BC783E3D0F10C HOSTID=ANY \SIGN=E2864CDA64EA383AFEATURE sx_daiclink sandwork 2010.12 01-dec-2010 uncounted FD821FFBAA4DA443D920 HOSTID=ANY \SIGN=95A44F82B1FC792CFEATURE sx_drc sandwork 2010.12 01-dec-2010 uncounted 0DF24F5B026CF1CEEDF4 HOSTID=ANY \SIGN=438A4F6CEAE41058FEATURE sx_wva sandwork 2010.12 01-dec-2010 uncounted 1D12FF8B0450D1BDEFF2 HOSTID=ANY \SIGN=F868E802B16CC48C
localhost.localdomain 是我linux的hostname
000FEA008949是网卡的物理地址
改后我执行命令: lmgrd -c ../../LIC/sx2006_license_2.dat
x2006_license_2.dat即改后的license
执行命令后报出信息:
23:54:31 (lmgrd)   Please Note:
23:54:31 (lmgrd)
23:54:31 (lmgrd)   This log is intended for debug purposes only.
23:54:31 (lmgrd)   There are many details in licensing policies
23:54:31 (lmgrd)   that are not reported in the information logged
23:54:31 (lmgrd)   here, so if you use this log file for any kind
23:54:31 (lmgrd)   of usage reporting you will generally produce
23:54:31 (lmgrd)   incorrect results.
23:54:31 (lmgrd)
23:54:31 (lmgrd) -----------------------------------------------
23:54:31 (lmgrd)
23:54:31 (lmgrd)
23:54:31 (lmgrd) lmgrd running as root:
23:54:31 (lmgrd)        This is a potential security problem
23:54:31 (lmgrd)        And is not recommended
23:54:31 (lmgrd) FLEXlm (v8.4a) started on localhost.localdomain (linux) (11/15/2009)
23:54:31 (lmgrd) Copyright (c) 1988-2003 by Macrovision Corporation. All rights reserved.
23:54:31 (lmgrd) US Patents 5,390,297 and 5,671,412.
23:54:31 (lmgrd) World Wide Web:  http://www.macrovision.com
23:54:31 (lmgrd) License file(s): ../../LIC/sx2006_license_2.dat
23:54:31 (lmgrd) lmgrd tcp-port 27000
23:54:31 (lmgrd) Starting vendor daemons ...
23:54:31 (lmgrd) Started sandwork (internet tcp_port 34200 pid 3641)
[root@localhost bin]# 23:54:31 (sandwork) FLEXnet Licensing version v10.8.0.1 build 19446
23:54:32 (sandwork) lmgrd version 8.4, sandwork version 10.8
23:54:32 (sandwork) Server started on localhost.localdomain for:        spice_explorer
23:54:32 (sandwork) sx_cdslink  sx_chip         sx_daiclink
23:54:32 (sandwork) sx_drc              sx_wva
23:54:32 (lmgrd) sandwork using TCP-port 34200
没有报什么错误,但是我用sx启动是还是出现这样的问题:
[root@localhost bin]# sx   no valid license found  please contact your system administrator
而且我在。bashrc里已经设置了:
export PATH=/synopsys/sx2006/binPATHexport LM_LICENSE_FILE=27000@000FEA008949
请朋友们帮忙,谢谢。
发表于 2009-11-16 09:12:58 | 显示全部楼层
06、07版本无需启lmgrd
.cshrc 下需要设定License的位置:
setenv SANDWORK_LICENSE_FILE (Install Dir)/license.dat
 楼主| 发表于 2009-11-16 19:13:18 | 显示全部楼层
十分感谢二楼,问题解决了。真是听君一句话,胜过自己乱撞半天的了。
发表于 2009-12-3 15:08:46 | 显示全部楼层
二楼的老师,我运行sx之后就会蹦出sx: need at least one file to send的信息,启动不了,这个怎么解决啊?
发表于 2010-4-16 12:00:01 | 显示全部楼层
THANKS~~~~~~~~~~~~~~
发表于 2010-11-23 12:49:13 | 显示全部楼层
谢谢分享 好
发表于 2012-2-8 16:00:39 | 显示全部楼层
麻烦问下,我安装时也报错sx: need at least one file to send 。然后,修改了.bashrc中的路径输出,还是有错。。。
export PATH=/usr/sandwork/bin PATH
还是存在错误,这个怎么解决丫?
谢谢
发表于 2012-9-12 10:55:53 | 显示全部楼层
也约到该问题了
发表于 2014-2-23 01:25:16 | 显示全部楼层
感謝分享 ~~
发表于 2014-7-1 16:50:30 | 显示全部楼层
把bin中文件改为可执行就可了
GMT+8, 2025-10-31 03:15 , Processed in 0.452371 second(s), 7 queries , Gzip On, Redis On.
