楼主: englishwin
晶振会因为gm过大而无法起振吗
发表于 2009-11-18 18:51:58 | 显示全部楼层
Thank you, but I don't think the value of bias resistor has anything to do with operating point. Voltage of two ends of resistor should be equal regardless of value, because there is no current path ...
englishwin 发表于 2009-11-18 18:41
If you do a DC analysis, you will see actually there is a small DC current through the feedback resistor. If this resistor is too large that we assume it's open. the input and output bias point of the inverter is very unstable.
发表于 2009-11-18 19:42:56 | 显示全部楼层
遇到过你同样的问题,在大概3v时能正常起振,大于3V就会不起振了,
加大外接的电容起振电压回上升;
如果你的现象也是如上的话,应该就睡你反相器的W/L大了,把它减小就好了,
当也是困惑好久,还好最后搞定了。
希望对你有帮助!
发表于 2009-11-18 20:09:31 | 显示全部楼层
工作频率是多少?
发表于 2009-11-18 23:37:28 | 显示全部楼层
18# jalover
我觉得反馈电阻应该越大越好,只要反馈电阻存在,总会提供一个直流通路使得输入输出相等,你说的假设一个极限:认为是断开的,但这个时候这个通路已经被打断了,但实际上只要Rf存在,这个通路就不是断开的
发表于 2010-3-11 09:13:28 | 显示全部楼层
非常感谢分享
发表于 2010-3-11 10:22:43 | 显示全部楼层
不同意反馈电阻越大越好,我们这边测试反馈电阻过大的话,会出现停振或振荡不稳定,,,
发表于 2011-2-15 16:49:52 | 显示全部楼层
学习了!
发表于 2011-11-18 23:00:05 | 显示全部楼层
if the rf is too large, considering i leakage, the bias voltage is wrong.
发表于 2016-4-27 16:29:03 | 显示全部楼层
这个问题很好
GMT+8, 2025-12-24 18:12 , Processed in 0.017297 second(s), 3 queries , Gzip On, Redis On.
