查看: 1864|回复: 6
Link to Ogata: Modern Control Engineering 4th Edition
发表于 2009-11-15 00:46:44 | 显示全部楼层 |阅读模式
Please visit the following website
http://www.eetop.cn/bbs/thread-216662-1-1.html
Fourth Edition
Katsuhiko Ogata
Amazon website
http://www.amazon.com/Modern-Control-Engineering-Katsuhiko-Ogata/dp/0130609072
Preface k
Chapter 1 Introduction toControl Systems 1
1-1 Introduction1
1-2 Examples ofControl Systems 3
1-3 Closed-LoopControl versus Open-Loop Control 6
1-4 Outline ofthe Book 8
Chapter 2 The Laplace Transform 9
2-1 Introduction9
2-2 Review of Complex Variables and Complex Functions 10
2-3 Laplace Transformation 13
2-4 Laplace Transform theorems 23
2-5 Inverse Laplace Transformation 32
2-6 Partial-Fraction Expansion with MATLAB 36
2-7 SolvingLinear, Time-Invariant, Differential Equations 40
Chapter 3 MathematicalModeling of Dynamic Systems
3-1 Introduction53
3-2 Transfer Function and Impulse-Response Function 55
3-3 Automatic Control Systems 58
3-2 Modeling in State Space 70
3-5 State-SpaceRepresentation of Dynamic Systems 76
3-6 Transformationof Mathematical Models with MATLAB
3-7 Mechanical Systems 85
3-8 Electricaland Electronic Systems 90
3-9 Signal Flow Graphs 104
3-10 Linearizationsof Nonlinear Mathematical Models
Chapter 4 MathematicalModeling of Fluid Systems and Thermal Systems
4-1 Introduction152
4-2 Liquid-Level Systems 153
4-3 Pneumatic Systems 158
4-4 Hydraulic Systems 175
4-5 Thermal Systems 188
Chapter 5 Transient andSteady-State Response Analyses
5-1 Introduction219
5-2 First-Order Systems 221
5-3 Second-Order Systems 224
5-4 Higher Order Systems 239
5-5Transient-Response Analysis with MATLAB 243
5-6 An Example Problem Solved with MATLAB 271
5-7 Routh'sStability Criterion 275
5-8 Effects ofIntegral and Derivative Control Actions on System Performance 281
5-9 Steady-StateErrors in Unity-Feedback Control Systems 288
Chapter 6 Root-LocusAnalysis 337
6-1 Introduction337
6-2 Root-LocusPlots 339
6-3 Summary of General Rules for Constructing Root Loci 351
6-4 Root-Locus Plots with MATLAB 358
6-5 Positive-Feedback Systems 373
6-6 Conditionally Stable Systems 378
6-7 Root Locifor Systems with Transport Lag 379
Chapter 7 Control SystemsDesign by the Root-Locus Method 416
7-1 Introduction416
7-2 Preliminary Design Considerations 419
7-3 Lead Compensation 421
7-4 Lag Compensation 429
7-5 Lag-Lead Compensation 439
7-6 Parallel Compensation 451
Chapter 8 Frequency-ResponseAnalysis 492
8-1 Introduction492
8-2 Bode Diagrams 497
8-3 Plotting Bode Diagrams with 1ATLAB 516
8-4 Polar Plots 523
8-5 Drawing Nyquist Plots with MATLAB 531
8-6 Log-Magnitude-versus-Phase Plots 539
8-7 Nyquìst Stability Criterion 540
8-8 Stability Analysis 550
8-9 Relative Stability 560
8-10 Closed-LoopFrequency Response of Unity-Feedback Systems 575
8-11 Experimental Determination of Transfer Functions 584
Chapter 9 Control SystemsDesign by Frequency Response
9-1 Introduction618
9-2 Lead Compensation 621
9-3 Lag Compensation 630
9-4 Lag-LeadCompensation 639
9-5 Concluding Comments 645
Chapter 10 PID Controlsand Two-Degrees-of-Freedom Control Systems
10-1Introduction 681
10-2 Tuning Rules for PID Controllers 682
10-3 Computational Approach to Obtain Optimal Sets of Parameter Values 692
10-4 Modifications of PID Control Schemes 700
10-5 Two-Degrees-of-Freedom Control 703
10-6 Zero-Placement Approach to Improve Response Characteristics 705
Chapter 11 Analysis ofControl Systems in State Space
11-1Introduction 752
11-2 State-Space Representations of Transfer-Function Systems 753
11-3 Transformation of System Models with MATLAB 760
11-4 Solving the Time-Invariant State Equation 764
11-5 Some Useful Results in Vector-Matrix Analysis 772
11-6 Controllability 779
11-7 Observability 786
Chapter 12 Design ofControl Systems in State Space 826
12-1 Introduction 826
12-2 Pole Placement 827
12-3 Solving Pole-Placement Problems with MATLAB 839
12-4 Design of Servo Systems 843
12-5 State Observers855
12-6 Design of Regulator Systems with Observers 882
12-7 Design of Control Systems with Observers 890
12-8 Quadratic Optimal Regulator Systems 897
发表于 2009-11-16 16:33:39 | 显示全部楼层
在那啊????
 楼主| 发表于 2009-11-16 18:43:43 | 显示全部楼层
2# hgp264721
发表于 2009-11-28 12:40:24 | 显示全部楼层
资料怎样上传,请给与说明一下,怎么我找不到上传的地方
发表于 2009-11-28 12:41:36 | 显示全部楼层
如何提高下载速度?怎么下载的速度这么慢?有时候还中断?
发表于 2010-3-19 10:18:06 | 显示全部楼层
发表于 2011-8-30 08:48:51 | 显示全部楼层
thank u so much ^^
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-9 03:57 , Processed in 0.017201 second(s), 5 queries , Gzip On, Redis On.
