查看: 7479|回复: 16
[图书]Practical FPGA Programming in C,chm格式有目录,绝对良心!!!
发表于 2009-11-5 13:41:26 | 显示全部楼层 |阅读模式
Preface
        C Language for FPGA-Based Hardware Design?
        Compelling Platforms for Software Acceleration
        The Power to Experiment
        How This Book Is Organized
        Where This Book Came From
     Acknowledgments
     Chapter 1.  The FPGA as a Computing Platform
        Section 1.1.  A Quick Introduction to FPGAs
        Section 1.2.  FPGA-Based Programmable Hardware Platforms
        Section 1.3.  Increasing Performance While Lowering Costs
        Section 1.4.  The Role of Tools
        Section 1.5.  The FPGA as an Embedded Software Platform
        Section 1.6.  The Importance of a Programming Abstraction
        Section 1.7.  When Is C Language Appropriate for FPGA Design?
        Section 1.8.  How to Use This Book
     Chapter 2.  A Brief History of Programmable Platforms
        Section 2.1.  The Origins of Programmable Logic
        Section 2.2.  Reprogrammability, HDLs, and the Rise of the FPGA
        Section 2.3.  Systems on a Programmable Chip
        Section 2.4.  FPGAs for Parallel Computing
        Section 2.5.  Summary
     Chapter 3.  A Programming Model for FPGA-Based Applications
        Section 3.1.  Parallel Processing Models
        Section 3.2.  FPGAs as Parallel Computing Machines
        Section 3.3.  Programming for Parallelism
        Section 3.4.  Communicating Process Programming Models
        Section 3.5.  The Impulse C Programming Model
        Section 3.6.  Summary
     Chapter 4.  An Introduction to Impulse C
        Section 4.1.  The Motivation Behind Impulse C
        Section 4.2.  The Impulse C Programming Model
        Section 4.3.  A Minimal Impulse C Program
        Section 4.4.  Processes Streams Signals, and Memory
        Section 4.5.  Impulse C Signed and Unsigned Datatypes
        Section 4.6.  Understanding Processes
        Section 4.7.  Understanding Streams
        Section 4.8.  Using Output Streams
        Section 4.9.  Using Input Streams
        Section 4.10.  Avoiding Stream Deadlocks
        Section 4.11.  Creading and Using Signals
        Section 4.12.  Understanting Registers
        Section 4.13.  Using Shared Memories
        Section 4.14.  Memory and Stream Performance Considerations
        Section 4.15.  Summary
     Chapter 5.  Describing a FIR Filter
        Section 5.1.  Design Overview
        Section 5.2.  The FIR Filter Hardware Process
        Section 5.3.  The Software Test Bench
        Section 5.4.  Desktop Simulation
        Section 5.5.  Application Monitoring
        Section 5.6.  Summary
     Chapter 6.  Generating FPGA Hardware
        Section 6.1.  The Hardware Generation Flow
        Section 6.2.  Understanding the Generated Structure
        Section 6.3.  Stream and Signal Interfaces
        Section 6.4.  Using HDL Simulation to Understand Stream Protocols
        Section 6.5.  Debugging the Generated Hardware
        Section 6.6.  Hardware Generation Notes
        Section 6.7.  Making Efficient Use of the Optimizers
        Section 6.8.  Language Constraints for Hardware Processes
        Section 6.9.  Summary
     Chapter 7.  Increasing Statement-Level Parallelism
        Section 7.1.  A Model of FPGA Computation
        Section 7.2.  C Language Semantics and Parallelism
        Section 7.3.  Exploiting Instruction-Level Parallelism
        Section 7.4.  Limiting Instruction Stages
        Section 7.5.  Unrolling Loops
        Section 7.6.  Pipelining Explained
        Section 7.7.  Summary
     Chapter 8.  Porting a Legacy Application to Impulse C
        Section 8.1.  The Triple-DES Algorithm
        Section 8.2.  Converting the Algorithm to a Streaming Model
        Section 8.3.  Performing Software Simulation
        Section 8.4.  Compiling To Hardware
        Section 8.5.  Preliminary Hardware Analysis
        Section 8.6.  Summary
     Chapter 9.  Creating an Embedded Test Bench
        Section 9.1.  A Mixed Hardware and Software Approach
        Section 9.2.  The Embedded Processor as a Test Generator
        Section 9.3.  The Role of Hardware Simulators
        Section 9.4.  Testing the Triple-DES Algorithm in Hardware
        Section 9.5.  Software Stream Macro Interfaces
        Section 9.6.  Building the Test System
        Section 9.7.  Summary
     Chapter 10.  Optimizing C for FPGA Performance
        Section 10.1.  Rethinking an Algorithm for Performance
        Section 10.2.  Refinement 1: Reducing Size by Introducing a Loop
        Section 10.3.  Refinement 2: Array Splitting
        Section 10.4.  Refinement 3: Improving Streaming Performance
        Section 10.5.  Refinement 4: Loop Unrolling
        Section 10.6.  Refinement 5: Pipelining the Main Loop
        Section 10.7.  Summary
     Chapter 11.  Describing System-Level Parallelism
        Section 11.1.  Design Overview
        Section 11.2.  Performing Desktop Simulation
        Section 11.3.  Refinement 1: Creating Parallel 8-Bit Filters
        Section 11.4.  Refinement 2: Creating a System-Level Pipeline
        Section 11.5.  Moving the Application to Hardware
        Section 11.6.  Summary
     Chapter 12.  Combining Impulse C with an Embedded Operating System
        Section 12.1.  The uClinux Operating System
        Section 12.2.  A uClinux Demonstration Project
        Section 12.3.  Summary
     Chapter 13.  Mandelbrot Image Generation
        Section 13.1.  Design Overview
        Section 13.2.  Expressing the Algorithm in C
        Section 13.3.  Creating a Fixed-Point Equivalent
        Section 13.4.  Creating a Streaming Version
        Section 13.5.  Parallelizing the Algorithm
        Section 13.6.  Future Refinements
        Section 13.7.  Summary
     Chapter 14.  The Future of FPGA Computing
        Section 14.1.  The FPGA as a High-Performance Computer
        Section 14.2.  The Future of FPGA Computing
        Section 14.3.  Summary
     Appendix A.  Getting the Most Out of Embedded FPGA Processors
        Section A.1.  FPGA Embedded Processor Overview
        Section A.2.  Peripherals and Memory Controllers
        Section A.3.  Increasing Processor Performance
        Section A.4.  Optimization Techniques That Are Not FPGA-Specific
        Section A.5.  FPGA-Specific Optimization Techniques
        Section A.6.  Summary
     Appendix B.  Creating a Custom Stream Interface
        Section B.1.  Application Overview
        Section B.2.  The DS92LV16 Serial Link for Data Streaming
        Section B.3.  Stream Interface State Machine Description
        Section B.4.  Data Transmission
        Section B.5.  Summary
     Appendix C.  Impulse C Function Reference
        CO_ARCHITECTURE_CREATE
        CO_BIT_EXTRACT
        CO_BIT_EXTRACT_U
        CO_BIT_INSERT
        CO_BIT_INSERT_U
        CO_EXECUTE
        CO_INITIALIZE
        CO_MEMORY_CREATE
        CO_MEMORY_PTR
        CO_MEMORY_READBLOCK
        CO_MEMORY_WRITEBLOCK
        CO_PAR_BREAK
        CO_PROCESS_CONFIG
        CO_PROCESS_CREATE
        CO_REGISTER_CREATE
        CO_REGISTER_GET
        CO_REGISTER_PUT
        CO_REGISTER_READ
        CO_REGISTER_WRITE
        CO_SIGNAL_CREATE
        CO_SIGNAL_POST
        CO_SIGNAL_WAIT
        CO_STREAM_CLOSE
        CO_STREAM_CREATE
        CO_STREAM_EOS
        CO_STREAM_OPEN
        CO_STREAM_READ
        CO_STREAM_READ_NB
        CO_STREAM_WRITE
        COSIM_LOGWINDOW_CREATE
        COSIM_LOGWINDOW_FWRITE
        COSIM_LOGWINDOW_INIT
        COSIM_LOGWINDOW_WRITE
     Appendix D.  Triple-DES Source Listings
        DES_HW.C
        DES.C
        DES_SW.C
        DES.H
     Appendix E.  Image Filter Listings
        IMG_HW.C
        IMG_SW.C
        IMG.H
     Appendix F.  Selected References
     Index
Practical FPGA Programming in C.part5.rar
2.12 MB, 下载次数: 38 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Practical FPGA Programming in C.part1.rar
3.81 MB, 下载次数: 36 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Practical FPGA Programming in C.part2.rar
3.81 MB, 下载次数: 37 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Practical FPGA Programming in C.part3.rar
3.81 MB, 下载次数: 38 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Practical FPGA Programming in C.part4.rar
3.81 MB, 下载次数: 40 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-11-5 15:19:22 | 显示全部楼层
thanks!
发表于 2009-11-5 17:04:13 | 显示全部楼层
学习 1# forestmeng
发表于 2009-11-5 20:11:06 | 显示全部楼层
不错啊
发表于 2009-11-5 23:27:24 | 显示全部楼层
xiexie
 楼主| 发表于 2009-11-9 13:38:36 | 显示全部楼层
好东西,大家加油,不要沉了,自己顶一下!!!
发表于 2009-11-9 22:55:58 | 显示全部楼层
谢谢楼主提供资料
发表于 2009-11-9 22:58:31 | 显示全部楼层
谢谢楼主提供资料
发表于 2009-11-9 23:02:00 | 显示全部楼层
谢谢楼主提供资料
发表于 2009-11-9 23:04:35 | 显示全部楼层
谢谢楼主提供资料
GMT+8, 2025-12-21 21:12 , Processed in 0.021605 second(s), 4 queries , Gzip On, Redis On.
