查看: 29766|回复: 143
[招聘] 【各level芯片研发类职位】【Verification Manager】职位更新~
发表于 2009-11-2 11:38:04 | 显示全部楼层 |阅读模式
Design Verification Manager
有8年以上相关工作经验,带过10人以上团队的,和我联系吧~
有详细JD,私下交流~
职位一
Senior Design Engineer for Video Codec
Preferred Experience:
- Major in EE and have Master degree or higher
- 3 years beyond working experience on ASIC design
- Must have strong background on video encoding/decoding algorithms
- Must be proficient in Verilog coding, debugging and modeling
- Must be skilled in ASIC design flow, such as synthesis, DFT, timing analysis, ECO etc.
- Must be skilled in mainstream EDA tools for design and simulation such as ncsim/vcs, RC/DC, PT, Formality/LEC and DFT.
- Must be familiar with verification methodologies for from block level to SoC level.
- Should be familiar with shell/perl/tcl programming in linux OS.
- Should be familiar with P&R and Manufacture tech.
- Good English hearing, speaking, reading and writing capabilities.
- Will be a big plus if having tape‐out experience.
- Will be a plus if having C/C++, matlab experience.
另staff,硕士5年以上相关经验,带过团队,有相应管理经验
职位二
Sr/MTS ASIC Design/Integration Engineer
PREFERRED EXPERIENCE:
- MSEE or PhD and CGPA of 8.0 out of 10.0 or higher with minimum 2-3 years of ASIC design and integration experience is required.
- Familiar with complex high speed ASIC Design process.
- Relevant experience in Graphics, Memory Controller (DDR, DDR2, DDR3), Video, Microprocessor Design, SOC design is a plus.
- Relevant experience in bus protocol USB/PCI/PCIE design is a plus.
- Relevant experience in chip level design/integration, DFT, memBIST, Memory Compiler, STA is a plus.
- Strong logic design, verification and debugging skills.
- Exposure to Digital systems and VLSI design, Computer Architecture, Computer Arithmetic, and C/C++ programming languages, CMOS transistors and circuits is optional.
- Good communications skills and ability and desire to work as a team player are a must.
职位三
Sr. /Jr. ASIC Design Verification Engineer
- MSEE or PhD and CGPA of 8.0 out of 10.0 or higher are required.
- Strong C/C++/System Verilog and HDL/RTL programming skills is a must.
- Relevant experience in Graphics, Memory Controller (DDR, DDR2, DDR3), Video, Microprocessor Design, SOC design and bus protocol PCIE is a plus.
- Strong logic analysis, verification, debugging and problem-solving skills.
- Relevant experience in Design for verification (Assertion Based Verification, code coverage, functional coverage, test plan, gate-level simulation, back-annotation etc.) is a plus.
- Relevant experience in Hardware emulation, System Performance modeling and analysis is an asset.
职位四
Sr. Physical Design Engineer
- PhD with 1+ years of industrial experience or MSEE with 3+ years of industrial experience in ASIC design
- Expertise in place and routing, signal integrity, power analysis, CTS design, DFT, design rule and connectivity verification, timing closure.
- Successfully gone through complete product development cycle. Good analytical and debugging skills
- Good listening, writing and speaking English.
- Good communication skills, strong interpersonal skills and the flexibility. Dedicated, hard working and good team player
- Familiar with Back-End (physical design) EDA tools (synopsys, cadence, magma)
- Familiar with Front-End EDA tools or circuit design is a plus
- Familiar with Unix/Linux environment and good at scripts.
另manager,硕士8年以上相关经验,有带项目经验
职位五
DFT Engineer
-   Master of EE or above. 2+ years DFT experience.
-   Prove million gates DFT project experience, and can handle complex DFT design independently.
-   Knowledge of Digital design, IC design methodology and Concepts of design for test.
-   Be familiar with verilog language
-   Be familiar with Unix and TCL, shell , Perl scripts.
-   Strong debug abilities.
-   Good English communication skills
-   Self-motivated and good team player.
以上职位base地点均在上海
需求量比较大
有兴趣的可直接发简历到邮箱,或MSN沟通
rongchris@hotmail.com
 楼主| 发表于 2009-11-3 10:26:27 | 显示全部楼层
up~~~up~~~
发表于 2009-11-3 15:57:31 | 显示全部楼层
看看!帮顶
 楼主| 发表于 2009-11-4 10:53:39 | 显示全部楼层
up...up...
 楼主| 发表于 2009-11-5 09:57:39 | 显示全部楼层
up~~~up~~~
 楼主| 发表于 2009-11-9 10:24:27 | 显示全部楼层
up~~~up~~~
 楼主| 发表于 2009-11-10 10:31:37 | 显示全部楼层
up~~~up~~~
 楼主| 发表于 2009-11-11 09:40:46 | 显示全部楼层
up~~~up~~~
发表于 2009-11-11 19:31:09 | 显示全部楼层
上海,可惜了
 楼主| 发表于 2009-11-12 10:35:52 | 显示全部楼层
恩。。。那你希望的是?
GMT+8, 2025-12-29 12:06 , Processed in 0.030030 second(s), 5 queries , Gzip On, Redis On.
