楼主 |
发表于 2009-10-10 19:22:43
显示全部楼层
我怎么看 * ***************************************************************************************
* GSMC Logic/Analog 0.18um 1P6M Industry Baseline Generic 1.8V/3.3V process SPICE MODEL *
工艺库里怎么没有呢?
只有 RAR压缩包 里只有 一个 gd018.l 的文件
而 gd018.l 只是一个 TXT文本文件。 如下图 是否还需要看具体的 说明呢?
* PROCESS : GSMC 0.18um 1P6M SALICIDE 1.8V/3.3V
* MODEL : BSIM3(V3.2) (Hspice level 49)
* VERSION : V1.4
* DATE : Nov 27, 2007
*In the input netlist, use the below .lib statements to call the desired models in gd018.l model file:
* Lib name Description
* .lib 'gd018.l' TT 1.8V nominal typical NMOS and typical PMOS models
* .lib 'gd018.l' SS 1.8V nominal slow NMOS and slow PMOS models
* .lib 'gd018.l' FF 1.8V nominal fast NMOS and fast PMOS models
* .lib 'gd018.l' SF 1.8V nominal slow NMOS and fast PMOS models
* .lib 'gd018.l' FS 1.8V nominal fast NMOS and slow PMOS models
* .lib 'gd018.l' TT_3V 3.3V nominal typical NMOS and typical PMOS models
* .lib 'gd018.l' SS_3V 3.3V nominal slow NMOS and slow PMOS models
* .lib 'gd018.l' FF_3V 3.3V nominal fast NMOS and fast PMOS models
* .lib 'gd018.l' SF_3V 3.3V nominal slow NMOS and fast PMOS models
* .lib 'gd018.l' FS_3V 3.3V nominal fast NMOS and slow PMOS models
* .lib 'gd018.l' TT_N 1.8V native typical NMOS models
* .lib 'gd018.l' SS_N 1.8V native slow NMOS models
* .lib 'gd018.l' FF_N 1.8V native fast NMOS models
* .lib 'gd018.l' SF_N 1.8V native slow NMOS models
* .lib 'gd018.l' FS_N 1.8V native fast NMOS models
* .lib 'gd018.l' TT_N3 3.3V native typical NMOS models
* .lib 'gd018.l' SS_N3 3.3V native slow NMOS models
* .lib 'gd018.l' FF_N3 3.3V native fast NMOS models
* .lib 'gd018.l' SF_N3 3.3V native slow NMOS models
* .lib 'gd018.l' FS_N3 3.3V native fast NMOS models
* .lib 'gd018.l' TT_M 1.8V MEDIUM Vt typical NMOS and typical PMOS models
* .lib 'gd018.l' SS_M 1.8V MEDIUM Vt slow NMOS and slow PMOS models
* .lib 'gd018.l' FF_M 1.8V MEDIUM Vt fast NMOS and fast PMOS models
* .lib 'gd018.l' SF_M 1.8V MEDIUM Vt slow NMOS and fast PMOS models
* .lib 'gd018.l' FS_M 1.8V MEDIUM Vt fast NMOS and slow PMOS models
* .lib 'gd018.l' TT_M3 3.3V MEDIUM Vt typical NMOS models
* .lib 'gd018.l' SS_M3 3.3V MEDIUM Vt slow NMOS and slow PMOS models
* .lib 'gd018.l' FF_M3 3.3V MEDIUM Vt fast NMOS and fast PMOS models
* .lib 'gd018.l' SF_M3 3.3V MEDIUM Vt slow NMOS and fast PMOS models
* .lib 'gd018.l' FS_M3 3.3V MEDIUM Vt fast NMOS and slow PMOS models
* .lib 'gd018.l' DIO 1.8V diode models
* .lib 'gd018.l' DIO3 3.3V diode models
* .lib 'gd018.l' DIO_DNW DNW related diode models
* .lib 'gd018.l' BIP_TT 1.8V Vertical PNP and NPN Bipolar typical models
* .lib 'gd018.l' BIP_FF 1.8V Vertical PNP and NPN Bipolar fast models
* .lib 'gd018.l' BIP_SS 1.8V Vertical PNP and NPN Bipolar slow models
* .lib 'gd018.l' BIP3_TT 3.3V Vertical PNP Bipolar typical models
* .lib 'gd018.l' BIP3_FF 3.3V Vertical PNP Bipolar fast models
* .lib 'gd018.l' BIP3_SS 3.3V Vertical PNP Bipolar slow models
* .lib 'gd018.l' RES_TT Resistor typical models
* .lib 'gd018.l' RES_FF Resistor fast models
* .lib 'gd018.l' RES_SS Resistor slow models
* .lib 'gd018.l' CAP_TT Typical MIM Capacitor models
* .lib 'gd018.l' CAP_FF Fast MIM Capacitor models
* .lib 'gd018.l' CAP_SS Slow MIM Capacitor models |
