查看: 8939|回复: 5
[讨论]看看我的第一个设计的资源利用情况。
发表于 2004-8-19 00:55:27 | 显示全部楼层 |阅读模式
用的是xc2s100fg256-6
是一个数字钟,有计时,闹钟,跑表,整点报时的功能。输出是7段数码管。
但是用synplify和XST综合后的差别很大。并且请大家看看用了这些资源是不是正常。
synplify综合后map的报告:
Design Summary
Number of errors:      0
Number of warnings:    1
Logic Utilization:
  Total Number Slice Registers:     166 out of  2,400    6%
    Number used as Flip Flops:                    165
    Number used as Latches:                         1
  Number of 4 input LUTs:           395 out of  2,400   16%
Logic Distribution:
    Number of occupied Slices:                         256 out of  1,200   21%
    Number of Slices containing only related logic:    256 out of    256  100%
    Number of Slices containing unrelated logic:         0 out of    256    0%
        *See NOTES below for an explanation of the effects of unrelated logic
Total Number 4 input LUTs:          410 out of  2,400   17%
      Number used as logic:                       395
      Number used as a route-thru:                 15
   Number of bonded IOBs:            38 out of    176   21%
   Number of GCLKs:                   4 out of      4  100%
Total equivalent gate count for design:  3,962
Additional JTAG gate count for IOBs:  1,824
Peak Memory Usage:  63 MB
XST综合后map的报告:
Design Summary
Number of errors:      0
Number of warnings:    3
Logic Utilization:
  Number of Slice Flip Flops:       197 out of  2,400    8%
  Number of 4 input LUTs:           483 out of  2,400   20%
Logic Distribution:
    Number of occupied Slices:                         334 out of  1,200   27%
    Number of Slices containing only related logic:    334 out of    334  100%
    Number of Slices containing unrelated logic:         0 out of    334    0%
Total Number 4 input LUTs:          550 out of  2,400   22%
      Number used as logic:                       483
      Number used as a route-thru:                 67
   Number of bonded IOBs:            36 out of    176   20%
      IOB Flip Flops:                               3
   Number of GCLKs:                   2 out of      4   50%
   Number of GCLKIOBs:                2 out of      4   50%
Total equivalent gate count for design:  5,059
差距咋这么大呢??:)
发表于 2004-8-19 09:55:51 | 显示全部楼层
这个本来就是synplify的强项啊。
发表于 2004-8-21 11:39:56 | 显示全部楼层
个人认为还是不要采用XST综合。曾经参加研讨会,有人说XST好,因为XILINX更了解它自己的期间结构。但我认为,综合效果的好坏与综合算法关系最大,这一点XILINX肯定不如synplicity了。
Synplify,Amplify,Precision都还不错。
发表于 2010-5-28 01:28:18 | 显示全部楼层
非常好用!!
发表于 2010-5-28 11:15:08 | 显示全部楼层
好,谢谢!
发表于 2010-5-28 16:23:28 | 显示全部楼层
支持~~~
GMT+8, 2025-12-26 14:41 , Processed in 0.024504 second(s), 8 queries , Gzip On, Redis On.
