楼主: xwlpxc
如何仿真电感Q~f ; Varactor电容的Q~V特性曲线?
发表于 2012-4-28 07:47:59 | 显示全部楼层
Varactor is nonlienar cap and varies with the amplitude (waveform) across it, and that is the reason for AM-FM conversion. For the oscillation frequency, the "averaging effective" capacitance, rather than the small signal capacitance, matters. You can apply a sine or square waveform at about the resonance frequency on the varactor and run PSS, then run PAC to get the effective capacitance. Typically, larger voltage amplitude results in smaller effective capacitance.
发表于 2012-5-3 17:08:02 | 显示全部楼层
回复 11# xftang
    那请问仿真的电路是怎样连接的呢,本人比较水,请指点一下。
发表于 2015-2-9 14:11:17 | 显示全部楼层
发表于 2015-2-9 14:12:32 | 显示全部楼层
发表于 2021-4-2 17:34:52 | 显示全部楼层
phase2000 发表于 2011-4-15 12:17
弱弱的问,啥叫SP 分析
SP(S parameter)S参数仿真
发表于 2022-3-15 23:30:15 | 显示全部楼层
xftang 发表于 2009-12-5 21:02
电感的Q=wL/R, 对电感做sp分析,计算z参数,Q=Z11(im)/Z11(re)
varactor的Q=1/wCR, 做sp分析,计算Z ...
学习一下
发表于 2022-3-16 09:01:35 | 显示全部楼层
谢谢了,在下再领会一下
发表于 2022-9-13 10:23:56 | 显示全部楼层
感谢分享
发表于 2022-10-19 15:56:20 | 显示全部楼层
感谢分享
发表于 2024-11-9 22:14:16 | 显示全部楼层
学习一下
GMT+8, 2025-12-29 02:07 , Processed in 0.023822 second(s), 4 queries , Gzip On, Redis On.
