发表于 2009-9-22 11:28:27
显示全部楼层
Although resistor matching can be calibrated, I don't recommend you use such an architecture. The input data BW is only 1.5KHz, so you can easily use a sigma-delta modulator, maybe 2nd order is good enough to achieve 70dB SNR. The total power consumption should very low as well. There's a mistake in my previous posting, SAR is not for DAC, but for ADC, sorry. |
