查看: 2077|回复: 1
helping
发表于 2004-8-4 12:00:20 | 显示全部楼层 |阅读模式
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity dctram is port(
  -- Inputs
  clk : in std_logic; -- Clock, async reset
  en, we : in std_logic; -- Sync enable, write enable
  ar : in std_logic_vector(5 downto 0); -- Read address
  aw : in std_logic_vector(5 downto 0); -- Write address
  din : in std_logic_vector(15 downto 0); -- Data input bus
  -- Outputs
  dout : out std_logic_vector(15 downto 0) -- Data output bus
end dctram;
architecture beh of dctram is
  type mram is array (63 downto 0) of std_logic_vector(15 downto 0);
  shared variable mem : mram; -- Memory array 64x16
begin
  -- Dual port RAM model
  process(clk) begin
    if clk'event and clk = '1' then
      -- Memory is written and read synchronoulsy
      -- when enabled
      if en = '1' then
        -- Write port
        if we = '1' then
          mem(conv_integer(aw)) := din;
        end if;
        -- Read port
        dout <= mem(conv_integer(ar));
      end if;
    end if;
  end process;
end beh;
--********modelsim error imply************************--
#vcom -work  work ram1/avgram.vhd
# vcom -work  work ram1/dctram.vhd
# Model Technology ModelSim SE vcom 5.7d Compiler 2003.05 May 10 2003
# -- Loading package standard
# -- Loading package std_logic_1164
# -- Loading package std_logic_arith
# -- Loading package std_logic_unsigned
# -- Compiling entity dctram
# -- Compiling architecture beh of dctram
# ** Error: ram1/dctram.vhd(45): near "shared": expecting: BEGIN
# ERROR: C:/Modeltech_5.7d/win32/vcom failed.
# Error in macro F:\mpeg4\MPEG-4\tb\compile.do line 90
# C:/Modeltech_5.7d/win32/vcom failed.
#     while executing
# "vcom -work  work ram1/dctram.vhd
发表于 2004-8-4 12:34:16 | 显示全部楼层
helping
这句type的定义语法有问题。
subtype word is std_logic_vector(15 downto 0);
type mram is array (integer range 0 to 63) of word;
mem也最好直接定义为signal。
GMT+8, 2025-12-26 09:41 , Processed in 0.022196 second(s), 6 queries , Gzip On, Redis On.
