查看: 2795|回复: 6
Design Techniques for Radiation-Hardened FPGAs
发表于 2009-9-13 10:12:31 | 显示全部楼层 |阅读模式
With the RH1280 and RH1020, Actel Corporation introduces radiation-hardened versions of the popular A1280 and A1020 field programmable gate array (FPGA) familes with equivalent gate densities of 8,000 and 2,000 gate array gates, respectively. These products are processed to the QML process flow as defined in MIL-PRF-38535. They are manufactured with a 0.8 micron, two-level metal epitaxial bulk CMOS technology, and offer total dose radiation-hardness in excess of 300K rads (Si) with guaranteed latch-up immunity. Because of this high total dose capability, the RH1280 and RH1020 are intended for use in applications including Earth orbiting satellites, deep space probes, and military electronics.
The RH1280 contains a total of 1232 logic modules. There are two types of logic modules: a combinatorial (C-module) and a sequential module (S-module). The S-module can implement the same combinatorial logic as the C-module, and it also contains a flip-flop that can be configured in several different
ways. Logic diagrams for the C-module and S-module are shown in Figure 1. The RH1280 contains 608 C-modules and 624 S-modules.
Design Techniques for Radiation-Hardened FPGAs.pdf
62.66 KB, 下载次数: 73 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2009-9-13 10:24:39 | 显示全部楼层
deng zi ji
deng!
发表于 2009-9-13 13:45:45 | 显示全部楼层
3ks3ks
发表于 2011-3-11 14:24:41 | 显示全部楼层
好书!
发表于 2012-1-13 19:45:15 | 显示全部楼层
发表于 2012-3-8 15:04:15 | 显示全部楼层
thanks!
发表于 2012-8-24 10:24:13 | 显示全部楼层
非常好的一本书 谢谢分享
GMT+8, 2025-8-20 09:55 , Processed in 0.020593 second(s), 7 queries , Gzip On, Redis On.
