查看: 1754|回复: 1
图标表示
发表于 2009-9-5 16:39:39 | 显示全部楼层 |阅读模式
As a result, the impact of di®erent types of catastrophic events like worm attacks,
power outages, accidental cable or link failures, etc. on connectivity in the Internet
becomes much more severe and longer lasting. Thus, maintaining the stability of
BGP is critical for preserving connectivity, thereby ensuring the delivery of data
packets. Our approach to solving this problem is to detect the occurrence of BGP
instabilities and to prevent their propagation. The detection algorithm proposed
here, performs a statistical analysis of features extracted from BGP update message
data to °ag the onset of an instability. We perform sequential change detection on
the feature time series using a Generalized Likelihood Ratio (GLR) based hypothesis
test. In order to make the detection more robust, we also exploit the temporal
correlation between changes detected across features and across peers. After the
detection, we propose techniques to analyze the update message contents to identify
the location of the root cause event. This information can then be used to design
BGP policy rules that can help to prevent the instability propagation. Our system
is designed to function online and can be deployed easily on any BGP router. We
evaluate our system using real BGP data from periods of a number of failure events
and SSFNet simulations. We show that it is e±cient in detecting instabilities with
minimum delay and very low false detection rates.
xiv
 楼主| 发表于 2009-9-5 16:41:13 | 显示全部楼层
哇塞,发错了也!
GMT+8, 2025-12-23 19:45 , Processed in 0.164230 second(s), 7 queries , Gzip On, Redis On.
