楼主: arrow4arrow
SRAM leakage reduction IEEE
发表于 2010-3-18 23:03:38 | 显示全部楼层
谢谢啦,不错
发表于 2010-3-24 04:21:24 | 显示全部楼层
thank you
发表于 2010-3-27 00:22:32 | 显示全部楼层
1# arrow4arrow
发表于 2010-3-27 13:10:22 | 显示全部楼层
Thanks a lot for share
发表于 2010-4-2 18:53:21 | 显示全部楼层
thanks for share!!!
发表于 2010-7-28 10:24:56 | 显示全部楼层
Abstract
Suppressing the leakage current in memories is critical
in low-power design. By reducing the standby supply voltage
(VDD) to its limit, which is the Data Retention Voltage (DRV),
leakage power can be substantially reduced. This paper explores
how low DRV can be in a standard low leakage
SRAM module and analyzes how DRV is affected by parameters
such as process variations, chip temperature, and transistor
sizing. An analytical model for DRV as a function of
process and design parameters is presented, and forms the
base for further design space explorations. This model is
verified using simulations as well as measurements from a
4KB SRAM chip in a 0.13 µm technology. It is demonstrated
that an SRAM cell state can be preserved at sub-300mV
standby VDD, with more than 90% leakage power savings.
发表于 2010-10-5 16:26:20 | 显示全部楼层
thanks for sharing
发表于 2010-10-18 12:26:14 | 显示全部楼层
谢谢了
发表于 2010-11-14 10:00:19 | 显示全部楼层
good reference for SRAM design,3q
发表于 2012-9-22 09:39:57 | 显示全部楼层
very useful.............
GMT+8, 2025-12-29 03:21 , Processed in 0.023638 second(s), 4 queries , Gzip On, Redis On.
