楼主: benemale
【ESD FMEA宝典】ESD: Failure Mechanisms and Models by Voldman
发表于 2011-4-16 00:45:11 | 显示全部楼层
好人啊,谢谢
发表于 2011-4-17 04:10:12 | 显示全部楼层
Take a look at "System and IC level analysis ESD and EFT immunity and associatied".
发表于 2011-4-17 04:15:55 | 显示全部楼层
Thank you for sharing!
发表于 2011-4-17 04:19:12 | 显示全部楼层
"ESD: Failure Mechanisms and Models"
It's a clear version!!!
发表于 2011-4-17 04:26:19 | 显示全部楼层
Content for your reference:
1 Failure Analysis and ESD 1
1.1 Introduction 1
1.1.1 FA Techniques for Evaluation of ESD Events 2
1.1.2 Fundamental Concepts of ESD FA Methods
and Practices 3
1.1.3 ESD Failure: Why Do Semiconductor Chips Fail? 4
1.1.4 How to Use FA to Design ESD Robust Technologies 5
1.1.5 How to Use FA to Design ESD Robust Circuits 6
1.1.6 How to Use FA for Temperature Prediction 7
1.1.7 How to Use Failure Models for Power Prediction 8
1.1.8 FA Methods, Design Rules, and ESD Ground Rules 9
1.1.9 FA and Semiconductor Process-Induced ESD Design
Asymmetry 9
1.1.10 FA Methodology and Electro-thermal Simulation 10
1.1.11 FA and ESD Testing Methodology 10
1.1.12 FA Methodology for Evaluation of ESD Parasitics 13
1.1.13 FA Methods and ESD Device Operation Verification 14
1.1.14 FA Methodology to Evaluate Inter-power Rail Electrical
Connectivity 14
1.1.15 How to Use FA to Eliminate Failure Mechanisms 16
1.2 ESD Failure: How Do Micro-electronic Devices Fail? 16
1.2.1 ESD Failure: How Do Metallurgical Junctions Fail? 18
1.2.2 ESD Failure: How Do Insulators Fail? 18
1.2.3 ESD Failure: How Do Metals Fail? 19
1.3 Sensitivity of Semiconductor Components 20
1.3.1 ESD Sensitivity as a Function of Materials 20
1.3.2 ESD Sensitivity as a Function of Semiconductor Devices 21
1.3.3 ESD Sensitivity as a Function of Product Type 21
1.3.4 ESD and Technology Scaling 22
1.3.5 ESD Technology Roadmap 24
1.4 How Do Semiconductor Chips Fail—Are the Failures Random
or Systematic? 24
1.5 Closing Comments and Summary 26
Problems 26
References 27
2 Failure Analysis Tools, Models, and Physics of Failure 31
2.1 FA Techniques for Evaluation of ESD Events 31
2.2 FA Tools 34
2.2.1 Optical Microscope 34
2.2.2 Scanning Electron Microscope 35
2.2.3 Transmission Electron Microscope 35
2.2.4 Emission Microscope 35
2.2.5 Thermally Induced Voltage Alteration 36
2.2.6 Superconducting Quantum Interference Device Microscope 37
2.2.7 Atomic Force Microscope 38
2.2.8 The 2-D AFM 40
2.2.9 Picosecond Current Analysis Tool 40
2.2.10 Transmission Line Pulse—Picosecond Current Analysis Tool 42
2.3 ESD Simulation: ESD Pulse Models 43
2.3.1 Human Body Model 43
2.3.2 Machine Model 44
2.3.3 Cassette Model 45
2.3.4 Socketed Device Model 46
2.3.5 Charged Board Model 46
2.3.6 Cable Discharge Event 47
2.3.7 IEC System-Level Pulse Model 49
2.3.8 Human Metal Model 50
2.3.9 Transmission Line Pulse Testing 51
2.3.10 Very Fast Transmission Line Pulse (VF-TLP) Model 53
2.3.11 Ultra-fast Transmission Line Pulse (UF-TLP) Model 53
2.4 Electro-Thermal Physical Models 54
2.4.1 Tasca Model 54
2.4.2 Wunsch–Bell Model 56
2.4.3 Smith–Littau Model 60
2.4.4 Ash Model 62
2.4.5 Arkihpov, Astvatsaturyan, Godovosyn, and Rudenko
Model 63
2.4.6 Dwyer, Franklin, and Campbell Model 63
2.4.7 Vlasov–Sinkevitch Model 67
2.5 Statistical Models for ESD Prediction 68
2.6 Closing Comments and Summary 70
Problems 70
References 71
3 CMOS Failure Mechanisms 77
3.1 Tables of CMOS ESD Failure Mechanisms 77
3.2 LOCOS Isolation-Defined CMOS 77
3.2.1 LOCOS-Bound Structures 82
3.2.2 LOCOS-Bound Pþ/N-well Junction Diode 83
3.2.3 LOCOS-Bound Nþ/P Substrate Junction Diode 84
3.2.4 LOCOS-Bound N-well/P Substrate Junction Diode 84
3.2.5 LOCOS-Bound Lateral N-well to N-well 85
3.2.6 LOCOS-Bound Lateral Nþ to N-well 85
3.2.7 LOCOS-Bound Lateral PNP Bipolar 85
3.2.8 LOCOS-Bound Thick Oxide MOSFET 85
3.3 Shallow Trench Isolation (STI) 86
3.3.1 STI Pull-down ESD Failure Mechanism 86
3.3.2 STI Pull-down and Gate Wrap-around 87
3.3.3 Silicides and Diodes 88
3.3.4 Non-silicide Diode Structures 88
3.3.5 STI-Defined Pþ/N-well Diode 88
3.3.6 STI-Defined N-well to Substrate Diode 88
3.3.7 STI Lateral N-well to N-well NPN Structures 90
3.4 Polysilicon-Defined Devices 90
3.4.1 Polysilicon-Bound Gated Diode 91
3.5 Lateral Diode with Block Mask 92
3.6 MOSFETs 92
3.6.1 N-channel MOSFETs 93
3.6.2 N-channel Multi-finger MOSFETs 95
3.6.3 Cascoded Series N-channel MOSFETs 97
3.6.4 P-channel MOSFETs 97
3.6.5 P-channel Multi-finger MOSFETs 98
3.6.6 Tungsten Silicide Gate MOSFET 98
3.6.7 Polysilicon Silicide Gate MOSFET 98
3.6.8 Metal Gate/High k Dielectric MOSFET 98
3.7 Resistors 99
3.7.1 Diffused Resistors 99
3.7.2 N-well Resistors 99
3.7.3 Buried Resistors 101
3.7.4 Silicide Blocked N-diffusion Resistors 102
3.8 Interconnects: Wires, Vias, and Contacts 102
3.8.1 Aluminum Interconnects 103
3.8.2 Copper Interconnects 104
3.8.3 Tungsten Interconnects 107
3.8.4 Vias 107
3.8.5 Contacts 110
3.9 ESD Failure in CMOS Nanostructures 112
3.9.1 ESD Failures in 130 nm Technology 112
3.9.2 ESD Failures in 90 nm Technology 113
3.9.3 ESD Failures in 65 nm Technology 114
3.9.4 ESD Failures in 45 nm Technology 115
3.9.5 ESD Failures in 32 nm Technology 115
3.9.6 ESD Failures in 22 nm Technology 116
3.10 Closing Comments and Summary 118
Problems 118
References 119
发表于 2011-4-17 04:27:47 | 显示全部楼层
4 CMOS Circuits: Receivers and Off-Chip Drivers 125
4.1 Tables of CMOS Receiver and OCD ESD Failure
Mechanisms 125
4.2 Receiver Circuits 125
4.3 Receivers Circuits with ESD Networks 127
4.3.1 Receiver with Dual Diode and Series Resistor 127
4.3.2 Receiver with Diode–Resistor–Diode 128
4.3.3 Receiver with Diode–Resistor–MOSFET 128
4.4 Receiver Circuits with Half-Pass Transmission Gate 131
4.5 Receiver with Full-Pass Transmission Gate 134
4.5.1 Receiver with Full-Pass Transmission Gate with Second
Power Source 135
4.6 Receiver, Half-Pass Transmission Gate, and Keeper Network 135
4.6.1 Receiver, Half-Pass Transmission Gate, and the Modified
Keeper Network 138
4.7 Receiver Circuits with Pseudo-Zero VT Half-Pass
Transmission Gate 139
4.8 Receiver with Zero VT Transmission Gate 141
4.9 Receiver Circuits with Bleed Transistors 143
4.10 Receiver Circuits with Test Functions 144
4.11 Receiver with Schmitt Trigger Feedback Networks 146
4.12 Off-Chip Drivers 148
4.12.1 OCD Design Process-Related ESD Failure 148
4.13 Single NFET Pull-down OCD 149
4.14 Series Cascode MOSFETs 150
4.15 I/O Design Considerations and ESD Parasitic Failure Mechanisms 152
4.15.1 Layout-Dependent ESD Failure Mechanisms 153
4.16 Closing Comments and Summary 155
Problems 155
References 156
5 CMOS Integration 159
5.1 Table of CMOS Integration ESD Failure Mechanisms 159
5.2 Architecture and Design Synthesis-Related Failures 159
5.3 Alternate Current Loop 161
5.4 Chip Capacitance 161
5.5 ESD Power Clamps 161
5.6 Intra- and Inter-domain ESD Protection 162
5.7 Split Ground Configurations 162
5.8 Mixed Voltage Interface 163
5.8.1 Peripheral VCC and Core VDD Power Rails 163
5.8.2 Two Power Supply: Peripheral and Core VDD
Power Rails 164
5.8.3 Voltage Regulators 166
5.9 Mixed Signal Interface 168
5.9.1 Digital and Analog 168
5.9.2 Digital, Analog, and RF 169
5.10 Inter-domain Signal Line ESD Failures 170
5.10.1 Digital-to-Analog Signal Line Failures 170
5.11 Decoupling Capacitors 173
5.12 System Clock and Phase-Locked Loop 174
5.13 Fuse Networks 174
5.13.1 Fuse Networks and ESD Failure Mechanisms 174
5.13.2 eFUSE and ESD Failure Mechanisms 176
5.14 Bond Pads 178
5.14.1 Floating Bond Pads 178
5.14.2 Floating Bond Pads over Interconnects 179
5.14.3 Bond Pad Failure: Programmable VDD 180
5.14.4 Bond Pad to Bond Pad ESD Failures 180
5.14.5 Bond Pad Failure: ESD Structures under Bond Pads 181
5.15 MOSFET Gate Structure 181
5.15.1 MOSFET Floating Gate and Floating Gate
Tie Down 181
5.15.2 MOSFET Gates Connected to Power VDD 182
5.16 Fill Shapes 182
5.17 No Connects 182
5.18 Test Circuitry 183
5.19 Multi-chip Systems 183
5.19.1 Multi-chip Systems on Multi-layer Ceramic 183
5.19.2 Multi-chip Systems and Silicon Carriers 184
5.19.3 Multi-chip Systems: Chip-to-Chip Failures with
Adjacent Chips 184
5.19.4 Multi-chip Systems: Proximity Communications 185
5.20 CMOS Latchup Failures 185
5.20.1 Table of Latchup Failures 185
5.20.2 Latchup Failure Mechanisms 187
5.21 Closing Comments and Summary 188
Problems 189
References 191
6 SOI ESD Failure Mechanisms 195
6.1 Tables of SOI Device and Integration ESD Failure Mechanisms 195
6.2 SOI N-channel MOSFETs 197
6.2.1 SOI Single-Finger N-channel MOSFETs 197
6.2.2 SOI Multi-finger MOSFETs 198
6.3 SOI Diodes 199
6.3.1 SOI Poly-bound Gated Diode 199
6.3.2 SOI Poly-bound Gated Diode with Halo Implants 199
6.4 SOI Buried Resistors 201
6.5 SOI Failure Mechanisms in 150 nm Technology 202
6.5.1 Lateral Graded Gated SOI Diode Structure 203
6.5.2 Lateral Ungated SOI Diode Structure 203
6.6 SOI ESD Failure Mechanisms in 45 nm Technology 204
6.6.1 SOI Lateral Gated Diode 204
6.6.2 SOI Double-Well Field Effect Device 204
6.6.3 SOI: ESD under BOX 205
6.7 SOI ESD Failure Mechanisms in 32 nm Technology 206
6.8 SOI ESD Failure Mechanisms in 22 nm Technology
and the Future 207
6.9 SOI Design Synthesis and ESD Failure Mechanisms 210
6.9.1 SOI ESD Circuit Failure Mechanisms 210
6.9.2 Mixed Voltage SOI ESD Circuit Failure Mechanisms 212
6.9.3 SOI Receiver Network ESD Failures 214
6.9.4 SOI Fuse Networks 215
6.9.5 SOI Dynamic Threshold Circuitry 215
6.9.6 SOI Active Clamp Circuitry 216
6.10 SOI Integration: ESD Failure Mechanisms 217
6.11 Closing Comments and Summary 218
Problems 218
References 220
发表于 2011-4-17 04:29:15 | 显示全部楼层
7 RF CMOS and ESD 225
7.1 Tables of RF CMOS ESD Failure Mechanisms 225
7.2 RF MOSFET 228
7.3 RF Shallow Trench Isolation Diode 229
7.4 RF Polysilicon Gated Diode 231
7.5 Silicon-Controlled Rectifier 232
7.6 Schottky Barrier Diodes 233
7.7 Capacitors 235
7.7.1 MIM Capacitor 236
7.7.2 Varactors and Hyper-abrupt Varactor Capacitors 237
7.7.3 Metal–ILD–Metal Capacitor 237
7.7.4 VPP Capacitor 237
7.7.5 Decoupling Capacitor 241
7.8 Resistors 241
7.8.1 Silicon Resistors 241
7.8.2 Polysilicon Resistors 241
7.8.3 Electronic Fuse (eFUSE) Resistor 241
7.9 Inductors 244
7.9.1 Planar Inductors 245
7.9.2 T-coil Inductor Pairs 248
7.10 Examples of RF ESD Circuit Failure Mechanisms 250
7.11 Closing Comments and Summary 253
Problems 253
Reference 254
8 Micro-electromechanical Systems 259
8.1 Table of MEM Failure Mechanisms 260
8.2 Electrostatically Actuated Devices 260
8.3 Micro-mechanical Engines 263
8.4 Torsional Ratcheting Actuator 265
8.5 Electromagnetic Micro-power Generators 267
8.6 MEM Inductors 269
8.7 Electrostatically Actuated Variable Capacitor 270
8.8 Micro-mechanical Switches 271
8.9 RF MEM Switch 271
8.10 Micro-mechanical Mirrors 277
8.11 Electrostatically Actuated Torsional Micro-mirrors 277
8.12 Closing Comments and Summary 281
Problems 281
References 282
9 Gallium Arsenide 287
9.1 Tables of GaAs-Based ESD Failure Mechanisms 287
9.2 GaAs Technology 290
9.3 GaAs Energy-to-failure and Power-to-failure 290
9.4 GaAs ESD Failures in Active and Passive Elements 293
9.5 GaAs HBT Devices 294
9.5.1 GaAs HBT Device ESD Results 295
9.5.2 GaAs HBT Diode Strings 296
9.6 GaAs HBT-Based Passive Elements 297
9.6.1 GaAs HBT Base–Collector Varactor 297
9.7 GaAs PHEMT Devices 298
9.7.1 GaAs PHEMT Low Noise Amplifiers 299
9.8 GaAs Power Amplifiers 300
9.8.1 GaAs PAs with Off-Chip Protection 303
9.9 InGaAs 303
9.9.1 InGaAs/AlGaAs PHEMT Devices 304
9.9.2 InGaAs/AlGaAs PHEMT ESD Failure 305
9.10 Gallium Nitride 306
9.10.1 GaN ESD Failure Mechanisms 307
9.11 InP and ESD 309
9.12 Closing Comments and Summary 309
Problems 309
References 310
发表于 2011-4-17 04:31:11 | 显示全部楼层
10 Smart Power, LDMOS, and BCD Technology 315
10.1 Tables of LDMOS ESD Failure Mechanisms 315
10.2 LOCOS-Defined LDMOS Devices 317
10.3 STI-Defined LDMOS Devices 319
10.4 STI-Defined Isolated LDMOS Transistors 320
10.5 LDMOS Transistors: ESD Electrical Measurements 321
10.6 LDMOS-Based ESD Networks 322
10.7 LDMOS ESD Failure Mechanisms 323
10.8 LDMOS Transistor Design Enhancement 324
10.9 Latchup Events in LDMOS and BCD Technology 324
10.10 Closing Comments and Summary 326
Problems 327
References 328
11 Magnetic Recording 333
11.1 Tables of Magnetic Recording Failure Mechanisms 333
11.2 MR Heads 334
11.2.1 MR Head Structure 335
11.2.2 MR Head Electrical Model 336
11.2.3 MR Head ESD Failures 337
11.2.4 AMR Head Failure Mechanisms 340
11.2.5 ESD Protection of MR Head 342
11.3 Inductive Heads 343
11.3.1 Inductive Head Structure 343
11.3.2 Inductive Head Structure: Electrical Schematic 344
11.3.3 Inductive Head Structure: ESD Failures 345
11.4 GMR Heads 346
11.4.1 GMR Head Structure 346
11.4.2 GMR Head ESD Failures 347
11.4.3 GMR Head ESD Protection 347
11.5 TMR Heads 349
11.5.1 TMR Structure 349
11.5.2 TMR ESD Results 349
11.5.3 TMR ESD Failure Mechanisms 351
11.6 ESD Solutions 351
11.6.1 Inductive Head Shunt 351
11.6.2 MR Shunt 351
11.6.3 Parasitic Magnetic Shields 352
11.6.4 Suspension ESD Shunt 352
11.6.5 Integration of a Silicon Chip 353
11.6.6 Deposited Amorphous Silicon ESD Diodes 353
11.6.7 Silicon Substrates 353
11.7 Closing Comments and Summary 354
Problems 354
References 355
12 Photo-masks and Reticles: Failure Mechanisms 361
12.1 Table of Photo-masks Failure Mechanisms 361
12.2 Photo-mask Failure Mechanisms 361
12.3 Photo-mask Inspection Tools 364
12.4 Photo-mask ESD Characterization 365
12.5 Electrical Breakdown versus Gap Spacing 365
12.6 Electrical Breakdown in Air: The Townsend Model 367
12.7 Electrical Breakdown in Air: Toepler’s Spark Law 367
12.8 Air Breakdown: The Paschen Breakdown Model 367
12.9 Paschen Curve versus Reticle Breakdown Plot 368
12.10 Electrical Model of Photo-mask Breakdown 369
12.11 ESD Latent Damage 371
12.12 ESD Damage for Single versus Multiple Events 372
12.13 ESD Damage to Anti-reflective Coating 373
12.14 ESD Solutions in Photo-masks 373
12.15 Closing Comments and Summary 375
Problems 375
References 376
Index 379
发表于 2011-4-23 14:16:11 | 显示全部楼层
都是好东西,都必须顶!!!
发表于 2011-6-1 01:18:20 | 显示全部楼层
Thanks for sharing this wonderful book!
GMT+8, 2025-12-27 17:35 , Processed in 0.023505 second(s), 4 queries , Gzip On, Redis On.
