查看: 11771|回复: 2
quartus使用中的license问题
发表于 2009-7-30 14:44:35 | 显示全部楼层 |阅读模式
我安装了quartus6.0,按照要求破解了license:Quartus6.0破解说明:
1.将CD2中\crack\windows\复制到<安装目录>\bin\下覆盖原有文件,如c:\altera\quartus60\bin\
2.将CD2中\crack\下的license.dat复制到硬盘任一目录下,如c:\altera\
3.编辑license.dat,替换"CHANGEME"为你的网卡MAC地址或硬盘号 to any type of hostid for your system:
Example:
HOSTID=00f0ffc0000f :网卡号
HOSTID=10018a3d :硬盘号
4.第一次运行Quartus时会让你指定license文件,选Specify valid license file,然后指定以上修改后的license.dat
可是在编译文件之后得到的是这样的error:
Warning: FLEXlm software error: Invalid (inconsistent) license key  The license-key and data for the feature do not match.  This usually happens when a license file has been altered Feature:       quartus License path:  C:\altera\license.dat FLEXlm error:  -8,523 For further information, refer to the FLEXlm End User Manual, available at "www.macrovision.com".
Error: Current license file does not support the EP2C35F672C6 device
Error: Quartus II Fitter was unsuccessful. 1 error, 1 warning
Error: Processing ended: Thu Jul 30 14:32:17 2009
Error: Elapsed time: 00:00:01
Error: Quartus II Full Compilation was unsuccessful. 1 error, 2 warnings
为什么呢,是我的license破解的不对么,还是需要安装sp1,和sp2
 楼主| 发表于 2009-7-30 15:20:54 | 显示全部楼层
问题解决了
哈哈,按照一位达人的破解方法就成功了,链接为http://www.cnblogs.com/oomusou/archive/2007/12/18/1004573.html
发表于 2014-3-19 02:44:37 | 显示全部楼层
Hi, Thank you
GMT+8, 2025-12-21 19:34 , Processed in 0.013274 second(s), 4 queries , Gzip On, Redis On.
