查看: 2669|回复: 0
Make WoW Gold For Your Epic Mount - wow gold
发表于 2009-7-17 21:25:17 | 显示全部楼层 |阅读模式
Some people have expressed concern about the difficulty of getting the epic flying mount. A lot of people think that the flying lessons are too expensive, but this guide will help you get your epic flyer. This guide is ideal for those that are starting out at level one.
The first thing that you need to wow gold do is develop good saving skills. Sounds a lot like real life, huh? If you learn how to save and you start saving early in the game, then it will be much easier on you when you need to spend a lot on your epic mount. One of the ways to help you with this is to get a bank toon.
&nbsp,wow gold;
You might think that the mailing fees will hurt you, but the bank toon will save you a lot of time so it will be worth it. It also helps because you will not be as tempted to spend the money if you have forgotten that you even have it.
You will also need to learn to make money as fast as possible. The best way to do this is to sell everything to a vendor. This is about maximizing the amount of money that you can get, so if you find that you don’t have enough world of warcraft gold room for a green item because you have grey ones, then get rid of some of the grey ones to free up space for the green items.
You also need to loot everything in sight. That means that you should go after every enemy that you run in to and you should look under everything you see. Sometimes the most expensive pieces are hiding in the spot that you would never think about. If you pass up a weak enemy because you think that you won’t get much out of it,wow gold, then you could have cost yourself a level 19 twink blue piece.
Be sure to collect all of the pieces of twink gear that you can. These can sell for a lot of gold and you could end up with enough money for your mount. You should also remember that sometimes you will get a random blue bind on equip piece which can be worth a lot of money.
Always sell at the AH. You might be able to make more money elsewhere, but you&rsquo,wow gold;ll be able to turn the items over faster at the AH. You should also impose a 24-hour time limit and sell during the weekend when there are more people that might buy your items.
You can also increase the amount of money that you have by choosing a gathering profession. You should get the gatherer wow gold mod if you have mining or herbalism. These professions can help you make a lot of money, which will obviously make it easier for you to get the epic mount. You should also give some consideration to your characters future. You will have the opportunity to change professions to something that you might find more interesting in the future. Right now you should be concerned about making money.
Be sure to bookmark this page and check out the other guides to make HUGE amounts of gold in this game.
Related Articles:
   Alchemy Vendors - world of warcraft gold
   Mage Class Guide - world of warcraft gold
GMT+8, 2025-12-13 21:15 , Processed in 0.015017 second(s), 7 queries , Gzip On, Redis On.
