查看: 32617|回复: 179
[2009新書]Integrated Power Electronic Converters and Digital Control_Ali Emadi
发表于 2009-7-16 21:24:58 | 显示全部楼层 |阅读模式
Publisher: CRC | Pages: 350 | 2009-05-18 | ISBN 1439800693 | PDF | 13 MB
Because of the demand for higher efficiencies, smaller output ripple, and smaller converter size for modern power electronic systems, integrated power electronic converters could soon replace conventional switched-mode power supplies. Synthesized integrated converters and related digital control techniques address problems related to cost, space, flexibility, energy efficiency, and voltage regulation—the key factors in digital power management and implementation.
Meeting the needs of professionals working in power electronics, as well as advanced engineering students, Integrated Power Electronic Converters and Digital Control explores the many benefits associated with integrated converters. This informative text details boost type, buck type, and buck-boost type integrated topologies, as well as other integrated structures. It discusses concepts behind their operation as well specific applications.
Integrated Power Electronic Converters and Digital Control_Ali Emadi.part1.rar
3.81 MB, 下载次数: 674 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Integrated Power Electronic Converters and Digital Control_Ali Emadi.part2.rar
3.81 MB, 下载次数: 645 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2009-7-16 21:34:43 | 显示全部楼层
Integrated Power Electronic Converters and Digital Control_Ali Emadi.part3.rar
3.81 MB, 下载次数: 555 , 下载积分: 资产 -2 信元, 下载支出 2 信元
Integrated Power Electronic Converters and Digital Control_Ali Emadi.part4.rar
3.22 MB, 下载次数: 549 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2009-7-16 21:39:21 | 显示全部楼层
Digital Control in Power Electronics_Simone Buso
Publisher:   Morgan and Claypool Publishers
Number Of Pages:   158
Publication Date:   2007-02-11
This book presents the reader, whether an electrical engineering student in power electronics or a design engineer, some typical power converter control problems and their basic digital solutions, based on the most widespread digital control techniques. The presentation is focused on different applications of the same power converter topology, the half-bridge voltage source inverter, considered both in its single- and three-phase implementation. This is chosen as the case study because, besides being simple and well known, it allows the discussion of a significant spectrum of the more frequently encountered digital control applications in power electronics, from digital pulse width modulation (DPWM) and space vector modulation (SVM), to inverter output current and voltage control. The book aims to serve two purposes: to give a basic, introductory knowledge of the digital control techniques applied to power converters, and to raise the interest for discrete time control theory, stimulating new developments in its application to switching power converters
Digital Control in Power Electronics_Simone Buso.pdf
2 MB, 下载次数: 500 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-7-16 21:48:35 | 显示全部楼层
thanks a lot
 楼主| 发表于 2009-7-16 21:51:35 | 显示全部楼层
Control Design Techniques in Power Electronics Devices _Hebertt J. Sira-Ramirez
Hebertt J. Sira-Ramirez, Ramon Silva-Ortigoza, "Control Design Techniques in Power Electronics Devices (Power Systems)"
Springer | 2006-06-21 | ISBN: 1846284589 | 444 pages | PDF | 8.2 MB
Power electronics systems are physical devices that can be modelled mathematically as controlled dynamical systems. This makes them suitable for the application of existing control theory, particularly in the design of their regulatory subsystems. For years there has been a perceived need to bring the disciplines of power electronics and theoretical control into closer co-operation, demonstrating the potentially great advantages of, at first sight, rather obscure control theory to power specialists while making control technicians better aware of the fundamental needs and limitations of power electronics design
Control Design Techniques in Power Electronics Devices _Hebertt J. Sira-Ramirez.part1.rar
4.29 MB, 下载次数: 351 , 下载积分: 资产 -3 信元, 下载支出 3 信元
Control Design Techniques in Power Electronics Devices _Hebertt J. Sira-Ramirez.part2.rar
3.95 MB, 下载次数: 368 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2009-7-17 12:54:41 | 显示全部楼层
thanks for sharing
发表于 2009-7-17 15:13:25 | 显示全部楼层
xiexiexiexiexie
发表于 2009-7-17 22:48:06 | 显示全部楼层
发表于 2009-7-17 23:04:12 | 显示全部楼层
发表于 2009-7-17 23:07:10 | 显示全部楼层
2009新書]Integrated Power Electronic Converters and Digital Control_Ali Emadi » 发表回复
GMT+8, 2025-11-5 16:46 , Processed in 0.024053 second(s), 6 queries , Gzip On, Redis On.
