查看: 8418|回复: 6
[help]Cadence ic610 帮助文档问题!
发表于 2009-7-16 13:41:07 | 显示全部楼层 |阅读模式
在openSUSE11.1下安装的cadence ic 610,在主界面上无法打开help中的文档,
在主界面中点击help下面的Cadence Documentation,出现help提示框
Some Cadence online documentation files are missing or can not opened duo to an error.
To start the Cadence documentation system, type cdsdoc at a system prompt.
同时在终端下出现如下:
/home/eda/ic610/tools/cdsdoc/bin/obServer: error while loadingsharedlibraries: libnsl.so.1: cannot open shared object file: No suchfile ordirectory
obApi: unable to contact /home/eda/ic610/tools/bin/obServer.
根据提示,在系统提示符下输入
**@**:~> cdsdoc
/home/eda/mmsim61/tools/jre/bin/java: error while loading shared libraries: libpthread.so.0: cannot open shared object file: No such file or directory
由于在.bashrc中加入了alias cdsbook='$CDS_ROOT/tools/bin/cdsdoc',所以又输入
**@**:~> cdsbook
/home/eda/ic610/tools/jre/bin/java: error while loading shared libraries: libpthread.so.0: cannot open shared object file: No such file or directory
哪位大虾,指点一下,非常感谢!!
[ 本帖最后由 lishyg 于 2009-7-17 00:16 编辑 ]
发表于 2010-5-23 19:16:44 | 显示全部楼层
我也遇到同样的问题,不知道楼主解决了没有?
发表于 2010-8-24 09:05:58 | 显示全部楼层
呱呱  龙叮咚
发表于 2010-9-13 19:01:35 | 显示全部楼层
问题多多
发表于 2010-9-14 03:32:16 | 显示全部楼层
好东西,谢谢
发表于 2010-10-7 12:20:05 | 显示全部楼层
install libpthread.so.0 library on your own.
发表于 2010-10-24 19:35:39 | 显示全部楼层
回复 1# lishyg
    问题解决了吗?楼主?
GMT+8, 2025-12-16 21:04 , Processed in 0.018079 second(s), 7 queries , Gzip On, Redis On.
