楼主: feiyufox
DC-DC buck降压不稳定请教
发表于 2011-5-26 23:58:26 | 显示全部楼层
其实这个问题,很是简单的,知道就是知道,不知道就是不知道,和哈
发表于 2011-5-27 10:40:50 | 显示全部楼层
What's the control loop type? Current mode, Voltage mode, or ripple based control?
If you designed this converter using the recommendation design from IC vender, then maybe your board design needs improvement. Normally, at high load or when you turn on and off the power supply, the ground will see larger switching noise which may have effects on your control loop, especially for current mode and ripple based control.
Thanks,
发表于 2011-5-27 10:43:17 | 显示全部楼层
try to increase the input capacitor and put it near to the power stage. That may help to minize the switching noise.
发表于 2011-6-1 17:27:55 | 显示全部楼层
回复 20# pe123
    看你深有体会的样子,投你一票!
发表于 2011-6-14 14:40:15 | 显示全部楼层
应该是过流保护引入的不稳定吧!你好好看看,工作的时候电感电流有没有超过过流值?OCP有没有触发。
发表于 2011-6-14 17:55:40 | 显示全部楼层
    对,要看下你得testbench是否将这些寄生参数加上,如果没有就太ideal咯
    如果正确地加入咯计生参数,一般来说仿真跟实际不会差太多的
发表于 2011-7-2 15:53:16 | 显示全部楼层
正在做DC 学习中
发表于 2011-10-25 09:53:48 | 显示全部楼层
回复 22# daroubao
    软启动不就是解决这个问题的?
发表于 2011-10-25 13:46:11 | 显示全部楼层
给点图看看吧
发表于 2011-10-29 22:57:16 | 显示全部楼层
补偿电容
GMT+8, 2025-12-30 16:18 , Processed in 0.021302 second(s), 3 queries , Gzip On, Redis On.
