查看: 5258|回复: 7
Help!on spiral inductor modeling!
发表于 2009-7-7 22:00:18 | 显示全部楼层 |阅读模式
Hi every buddy,
I'm using VPCM from MMSIM61 in IC610 platform for modeling spiral inductor .After generating cell,I could only open layout view.But I can't open any other view such as symbol,schematic.In the CIW prompt window,it gives the following warning:
*WARNING* dbOpenCellViewByType: Design database revision (59) is not compatible with current revision (99).
So what 's wrong with me?
My component type is differential inductor and shape is octagonal with 2 ports.
Accuracy selection:Full-Wave EM Solver.
Please,anybody can help mee!
Thank you in advance!
发表于 2009-7-8 20:46:19 | 显示全部楼层
建议使用ASITIC+Momentum+MicrowaveOffice软件进行电感的建模。
VPCM使用较少,ECC license问题,破解版本较少。
 楼主| 发表于 2009-7-9 09:32:36 | 显示全部楼层
好的
我在cadence的forum发了帖子,询问VPCM电感建模的问题
回复说今年圣诞就是VPCM/VPCD的EOL
http://www.cadence.com/community/forums/T/12893.aspx
[ 本帖最后由 tjjbraye 于 2009-7-10 16:10 编辑 ]
发表于 2015-5-26 11:32:10 | 显示全部楼层
电磁场建模仿真解决方案.pdf (1.77 MB , 下载次数: 80 )
电磁场建模仿真解决方案参考
发表于 2015-7-14 14:45:18 | 显示全部楼层
这个可以看看
发表于 2015-10-14 13:15:52 | 显示全部楼层
好好好
发表于 2016-6-25 10:48:15 | 显示全部楼层
THANK YOU
发表于 2017-4-11 15:57:58 | 显示全部楼层
Thank you!
GMT+8, 2025-12-17 05:10 , Processed in 0.019404 second(s), 5 queries , Gzip On, Redis On.
