查看: 4462|回复: 6
Calibre XRC反提出来的网表,有问题啊,来人救命啊
发表于 2009-7-6 17:48:27 | 显示全部楼层 |阅读模式
做完版图后,使用calibre反提网表,网表顺利得到了,不过自己在看网表的时候,发现里面不少管子的名字重了,不解啊,仿真的时候也报错,大家帮我看看啊!(网表如下,按颜色分)
m__21 N_XI9/net097___21_d N_ID2S___21_g N_VDDA___21_s N_VDDA_XI9/MM32_b pch3
+ L=4e-07 W=1e-05 AD=4.8e-12 AS=4.8e-12 PD=2.096e-05 PS=2.096e-05 NRD=0.048
+ NRS=0.048
m__22 N_XI9/net097___22_d N_ID2S___22_g N_VDDA___22_s N_VDDA_XI9/MM32_b pch3
+ NRS=0.048
m__21 N_XI9/net71___21_d N_ID2S___21_g N_VDDA___21_s N_VDDA_XI9/MM32_b pch3
+ NRS=0.048
m__22 N_XI9/net71___22_d N_ID2S___22_g N_VDDA___22_s N_VDDA_XI9/MM32_b pch3
+ NRS=0.048
m__23 N_XI9/net71___23_d N_ID2S___23_g N_VDDA___23_s N_VDDA_XI9/MM32_b pch3
+ NRS=0.048
m__24 N_XI9/net71___24_d N_ID2S___24_g N_VDDA___24_s N_VDDA_XI9/MM32_b pch3
+ NRS=0.048
m__23 N_XI9/net097___23_d N_ID2S___23_g N_VDDA___23_s N_VDDA_XI9/MM32_b pch3
+ NRS=0.048
m__24 N_XI9/net097___24_d N_ID2S___24_g N_VDDA___24_s N_VDDA_XI9/MM32_b pch3
+ NRS=0.048
发表于 2009-7-6 19:32:05 | 显示全部楼层
是不是有些网表文件要经过修改才能用的呢?
发表于 2009-7-7 14:27:55 | 显示全部楼层
could you provide the command file ?that is easy to see where the problem is.
发表于 2009-9-1 21:39:52 | 显示全部楼层
确实要从你的rule file入手才能解决问题。
发表于 2010-5-28 10:02:50 | 显示全部楼层
可能是自己错了。。。
发表于 2010-5-28 10:55:04 | 显示全部楼层
应先看看Rule有没有问题,实在没办法就改网表吧
发表于 2010-6-28 14:10:56 | 显示全部楼层
路过    看看
GMT+8, 2025-12-30 03:36 , Processed in 0.021130 second(s), 7 queries , Gzip On, Redis On.
