楼主: snowyd
谁会?
发表于 2004-5-26 00:02:56 | 显示全部楼层
谁会?
[这个贴子最后由serene在 2004/05/26 00:04am 第 2 次编辑]
stg1_butterfly.vhd大致应该是这样的:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity stg1_butterfly is
      generic(
             data_width     : integer := 16;                                             -- 前面已经有注释
             int_data_width : integer := 16;
             tw_fact_width  : integer := 16);
      port   (
             reset          : in std_logic;
             clk            : in std_logic;
             data_rd        : in std_logic;
             data1_r_in     : in  std_logic_vector(data_width-1 downto 0);
             data1_i_in     : in  std_logic_vector(data_width-1 downto 0);
             data2_r_in     : in  std_logic_vector(data_width-1 downto 0);
             data2_i_in     : in  std_logic_vector(data_width-1 downto 0);
             tf1_r          : in  std_logic_vector(tw_fact_width-1 downto 0);
             data1_r_out    : out std_logic_vector(int_data_width-1 downto 0);
             data1_i_out    : out std_logic_vector(int_data_width-1 downto 0);
             data2_r_out    : out std_logic_vector(int_data_width-1 downto 0);
             data2_i_out    : out std_logic_vector(int_data_width-1 downto 0)
end stg1_butterfly;
architecture rtl of stg1_butterfly is
component Multiplier
generic(
             multiplier_width      : integer := 16;
             data_width            : integer := 16);
        port (
             load        : in std_logic;
             mult1_data  : in std_logic_vector(data_width-1 downto 0);
             mult2_data  : in std_logic_vector(multiplier_width-1 downto 0);
             product     : out std_logic_vector(multiplier_width+data_width-2 downto (multiplier_width-1)) -- 乘积输出
end component;
signal last_data_rd                : std_logic;                                    -- 用于读取数据
signal data1_r_in_div4             : std_logic_vector(data_width-1 downto 0);      -- (data1/4)的实部
signal data1_i_in_div4             : std_logic_vector(data_width-1 downto 0);      -- (data1/4)的虚部
signal Butt_Data1_Out_R_signed     : signed (data_width-1 downto 0);               -- butterfly的data1实部输出
signal Butt_Data1_Out_I_signed     : signed (data_width-1 downto 0);               -- butterfly的data1虚部输出
signal Butt_Data2_Out_R_signed     : signed (data_width-1 downto 0);               -- butterfly的data2实部输出
signal Butt_Data2_Out_I_signed     : signed (data_width-1 downto 0);               -- butterfly的data2虚部输出
signal Mult_A_C_Out                : std_logic_vector(data_width-1 downto 0);      -- 乘法器输出(实部)
signal Mult_A_D_Out                : std_logic_vector(data_width-1 downto 0);      -- 乘法器输出(虚部)
begin
stg1_butterfly_calcs:
process(data1_r_in_div4, data1_i_in_div4, Mult_A_C_Out, Mult_A_D_Out)
-- 该进程用于butterfly的输出,其值=原输出/4。
begin
  Butt_Data1_Out_R_signed <= signed(data1_r_in_div4) + signed(Mult_A_C_Out);
  Butt_Data1_Out_I_signed <= signed(data1_i_in_div4) + signed(Mult_A_D_Out);
  Butt_Data2_Out_R_signed <= signed(data1_r_in_div4) - signed(Mult_A_C_Out);
  Butt_Data2_Out_I_signed <= signed(data1_i_in_div4) - signed(Mult_A_D_Out);
end process stg1_butterfly_calcs;
data_scaling:
process(reset, clk)
-- 该进程用于比例变换,为防乘法器溢出,相乘数据/2,乘积即为原来的1/4,所以对data1_in进行变换,存于data1_in_div4。
begin
  if reset = '0' then
     data1_r_in_div4 <= (others => '0');
     data1_i_in_div4 <= (others => '0');
  elsif Rising_Edge(clk) then
     if data1_r_in(data_width-1) = '0' then
        data1_r_in_div4 <= "00" & data1_r_in(data_width-1 downto 2);
     else
        data1_r_in_div4 <= "11" & data1_r_in(data_width-1 downto 2);
     end if;
     if data1_i_in(data_width-1) = '0' then
        data1_i_in_div4 <= "00" & data1_i_in(data_width-1 downto 2);
     else
        data1_i_in_div4 <= "11" & data1_i_in(data_width-1 downto 2);
     end if;
  end if;
end process data_scaling;
-- 输出=原输出值/2,这里实际需要对Butt_Data值乘2。
data1_r_out <= std_logic_vector(Butt_Data1_Out_R_signed(data_width-2 downto 0)) & '0';
data1_i_out <= std_logic_vector(Butt_Data1_Out_I_signed(data_width-2 downto 0)) & '0';
data2_r_out <= std_logic_vector(Butt_Data2_Out_R_signed(data_width-2 downto 0)) & '0';
data2_i_out <= std_logic_vector(Butt_Data2_Out_I_signed(data_width-2 downto 0)) & '0';
--butterfly乘积实部计算
A_C_Mult: Multiplier
generic map (
                  multiplier_width => data_width,
                  data_width       => tw_fact_width
         port map (
                  load             => data_rd,
                  mult1_data       => tf1_r,
                  mult2_data       => data2_r_in,
                  product          => Mult_A_C_Out
--butterfly乘积虚部计算
A_D_Mult: Multiplier
generic map (
         port map (
                  load             => data_rd,
                  mult2_data       => data2_i_in,
                  product          => Mult_A_D_Out
end rtl;
发表于 2004-5-26 00:08:20 | 显示全部楼层
谁会?
下面引用由snowyd2004/05/25 06:01pm 发表的内容:
你的New Sample Read(上升沿)是指,有上升沿时就读数据?
现在再想想,好象上升沿不是太合理,就用高电平吧。前面的注释我已修改。
 楼主| 发表于 2004-5-26 09:23:39 | 显示全部楼层
谁会?
fft这样做可以吗?entity fft is
      generic(
             coeff_width : integer := 16;
             fft_length  : integer := 64);
      port   (
             RESET       : in  std_logic;                               -- 复位,假设低有效
             clk         : in  std_logic;                               -- 输入时钟
             START       : in  std_logic;                               -- 开始变换信号
             DATA_RD     : in  std_logic;                               -- New Sample Read (上升沿)
             DR          : in  std_logic_vector(Data_width-1 downto 0); -- 实部输入
             DI          : in  std_logic_vector(Data_width-1 downto 0); -- 虚部输入
             ADDRESS     : in  std_logic_vector(6 downto 0);            -- 输出矩阵地址
             XK_R        : out std_logic_vector(Data_width-1 downto 0); -- 实部输出
             XK_I        : out std_logic_vector(Data_width-1 downto 0); -- 虚部输出
             RES_VALID   : out std_logic                                -- 输出有效指示
end fft;
architecture FFT of fft  is
  component fft
      port (
        clk      : in  std_logic;
        DR15     : in std_logic;
        DR14     : in std_logic;
        DR13     : in std_logic;
        DR12     : in std_logic;
        DR11     : in std_logic;
        DR10     : in std_logic;
        DR9     : in std_logic;
        DR8     : in std_logic;
        DR7     : in std_logic;
        DR6     : in std_logic;
        DR5     : in std_logic;
        DR4     : in std_logic;
        DR3     : in std_logic;
        DR2     : in std_logic;
        DR1     : in std_logic;
        DR0     : in std_logic;
        DI15     : in std_logic;
        DI14     : in std_logic;
        DI13     : in std_logic;
        DI12     : in std_logic;
        DI11     : in std_logic;
        DI10     : in std_logic;
        DI9     : in std_logic;
        DI8     : in std_logic;
        DI7     : in std_logic;
        DI6     : in std_logic;
        DI5     : in std_logic;
        DI4     : in std_logic;
        DI3     : in std_logic;
        DI2     : in std_logic;
        DI1     : in std_logic;
        DI0     : in std_logic;
        RES_VALID  : out std_logic;
        XK_R15  : out std_logic;
        XK_R14  : out std_logic;
        XK_R13  : out std_logic;
        XK_R12  : out std_logic;
        XK_R11  : out std_logic;
        XK_R10  : out std_logic;
        XK_R9  : out std_logic;
        XK_R8  : out std_logic;
        XK_R7  : out std_logic;
        XK_R6  : out std_logic;
        XK_R5 : out std_logic;
        XK_R4  : out std_logic;
        XK_R3  : out std_logic;
        XK_R2  : out std_logic;
        XK_R1  : out std_logic;
        XK_R0  : out std_logic;
        XK_I15  : out std_logic;
        XK_I14  : out std_logic;
        XK_I13  : out std_logic;
        XK_I12  : out std_logic;
        XK_I11  : out std_logic;
        XK_I10  : out std_logic;
        XK_I9  : out std_logic;
        XK_I8  : out std_logic;
        XK_I7  : out std_logic;
        XK_I6  : out std_logic;
        XK_I5  : out std_logic;
        XK_I4  : out std_logic;
        XK_I3  : out std_logic;
        XK_I2  : out std_logic;
        XK_I1  : out std_logic;
        XK_I0  : out std_logic
         end component;
begin
  FFT64: fft
    port map (
        RS    => RS ,
        DR15    => DR(15) ,
        DR14    => DR(14) ,
        DR13    => DR(13) ,
        DR12    => DR(12) ,
        DR11    => DR(11) ,
        DR10    => DR(10) ,
        DR9     => DR(9) ,
        DR8     => DR(8) ,
        DR7     => DR(7) ,
        DR6     => DR(6) ,
        DR5     => DR(5) ,
        DR4     => DR(4) ,
        DR3     => DR(3) ,
        DR2     => DR(2) ,
        DR1     => DR(1) ,
        DR0     => DR(0) ,
        DI15    => DI(15) ,
        DI14    => DI(14) ,
        DI13    => DI(13) ,
        DI12    => DI(12) ,
        DI11    => DI(11) ,
        DI10    => DI(10) ,
        DI9     => DI(9) ,
        DI8     => DI(8) ,
        DI7     => DI(7) ,
        DI6     => DI(6) ,
        DI5     => DI(5) ,
        DI4     => DI(4) ,
        DI3     => DI(3) ,
        DI2     => DI(2) ,
        DI1     => DI(1) ,
        DI0     => DI(0) ,
        START   => START ,
        clk     => clk ,
        RES_VALID   =>RES_VALID,
        XK_R15   => XK_R(15) ,
        XK_R14   => XK_R(14) ,
        XK_R13   => XK_R(13) ,
        XK_R12   => XK_R(12) ,
        XK_R11   => XK_R(11) ,
        XK_R10   => XK_R(10) ,
        XK_R9    => XK_R(9) ,
        XK_R8    => XK_R(8) ,
        XK_R7    => XK_R(7) ,
        XK_R6    => XK_R(6) ,
        XK_R5    => XK_R(5) ,
        XK_R4    => XK_R(4) ,
        XK_R3    => XK_R(3) ,
        XK_R2    => XK_R(2) ,
        XK_R1    => XK_R(1) ,
        XK_R0    => XK_R(0) ,
        XK_I15   => XK_I(15) ,
        XK_I14   => XK_I(14) ,
        XK_I13   => XK_I(13) ,
        XK_I12   => XK_I(12) ,
        XK_I11   => XK_I(11) ,
        XK_I10   => XK_I(10) ,
        XK_I9    => XK_I(9) ,
        XK_I8    => XK_I(8) ,
        XK_I7    => XK_I(7) ,
        XK_I6    => XK_I(6) ,
        XK_I5    => XK_I(5) ,
        XK_I4    => XK_I(4) ,
        XK_I3    => XK_I(3) ,
        XK_I2    => XK_I(2) ,
        XK_I1    => XK_I(1) ,
        XK_I0    => XK_I(0));
end FFT;
发表于 2004-5-26 09:34:57 | 显示全部楼层
谁会?
对于乘法器的说明:
一般来说用纯小数或纯整数乘法比较容易确定小数点的位置,不易搞错。
这里采用x.xxxxxxx xxxxxxxx格式的两数相乘,乘积为:
yy.yyyyyy yyyyyyyy (yyyyyyyy yyyyyyyy)格式,对该值左移1位,成为:
y.yyyyyyy yyyyyyyy格式。这样做是为了计算上小数点不易搞错。
发表于 2004-5-26 09:41:57 | 显示全部楼层
谁会?
前面的stg1_butterfly要用到乘法器,这个还比较简单,multiplier.vhd可以是:
library ieee;
entity multiplier is
  generic(multiplier_width       : natural;
          data_width             : natural);
  port(
          load         : in std_logic;                                                  -- 输入数据ready
          mult1_data   : in std_logic_vector(multiplier_width-1 downto 0);              -- Data1
          mult2_data   : in std_logic_vector(data_width-1 downto 0);                    -- Data2
end multiplier;
architecture rtl of multiplier is
signal t_product       : std_logic_vector(multiplier_width+data_width-1 downto 0);      -- 乘积
begin
  process (load, mult1_data, mult2_data)
  begin
    if load = '1' then
      t_product <= std_logic_vector(signed(mult1_data) * signed(mult2_data));
    end if;
  end process;
product <= t_product(multiplier_width+data_width-2 downto (multiplier_width-1));
end rtl;
发表于 2004-5-26 09:59:33 | 显示全部楼层
谁会?
[这个贴子最后由serene在 2004/05/26 10:08am 第 1 次编辑]
建议先将stg1_butterfly编译仿真一下看看,验证一下正确与否。
对于butterfly这个component,由于旋转因子含有虚部,所以要用复数乘法来替代前面的multiplier。其乘数有实部、虚部,乘积也含有实部、虚部。复数乘法器可以调用multiplier来实现。
发表于 2004-5-26 23:33:03 | 显示全部楼层
谁会?
下面引用由snowyd2004/05/26 09:23am 发表的内容:
      generic(
             coeff_width = 16;
             data_width  = 16;
感觉上,数组还是用std_logic_vector比较好,看起来简洁明了,行数也会少很多。
如果你的project就是这个FFT,不是其它应用调用FFT模块,也可以不写fft component,直接在architecture里写好了,因为已经是最顶层了。
发表于 2004-5-27 00:25:04 | 显示全部楼层
谁会?
[这个贴子最后由serene在 2004/05/27 00:27am 第 2 次编辑]
fft的architecture建议这样考虑:
architecture fft_architecture of fft is
--component dual_port_ram 前面已经有描述
--component stg1_butterfly 前面已经有描述
--component butterfly 前面已经有描述
--constant subtype type 等
--signal 定义
begin
--旋转因子实部、虚部赋值
-- process-data_average: 输入数据存入Ram1和Ram2前计算其平均值,该值用作stg1_butterfly的数据输入
-- process-reverse_address: 新数据到达后指示bit reversal,bit reversal结束后指示可以取新数据
-- process-reverse_bits:reverse存储地址,使数据写入正确的 Ram1和Ram2地址
-- process-选择Ram1和Ram2中的实部或虚部copy到FFT array
-- process-将Ram1和Ram2中的实部和虚部数据copy到FFT array
-- process-计算完成、结果有效指示
-- 结果输出到data_out
-- Component例化:
-- Ram1
-- Ram2
-- Stage1-6 Butterfly,这里的内容会很长。
end;
 楼主| 发表于 2004-5-27 22:51:03 | 显示全部楼层
谁会?
现在我已经将旋转因子装到rom里面!
还有我打算输入数据全部变换成0和1之间的定点小数,这样跟旋转因子一样了1!
还有蝶形图我打算就用第二个,第一个省掉1!
处理上第一级把虚部等于0!!!!
还有对于fft作为最顶层
时!你说的思想,我不能完全明白?
发表于 2004-5-28 00:16:34 | 显示全部楼层
谁会?
是啊,从程序上看,两个蝶形图可以合并的,但不清楚会不会多占资源。
从数学角度看,每个stage有32个butterflies,共有6个stage,很费资源的,估计编译都要化一定时间的。
对于fft作为最顶层,是你的peoject决定的,如果你的peoject就是这个FFT,那就不必做fft component了;如果是其它的功能中需要调用FFT,那么就做成component,因为那个功能才是最顶层,这样比较明了。
呵呵,做出来后,一定要告诉我结果啊,如所耗的资源、能达到的Fmax等。
另外,我觉得好象曾看到的你的有些回帖找不到了,郁闷。
GMT+8, 2025-12-20 10:31 , Processed in 0.035726 second(s), 4 queries , Gzip On, Redis On.
