楼主: snowyd
谁会?
发表于 2004-6-21 14:21:07 | 显示全部楼层
谁会?
--rms.vhd和sqrt.vhd用于产生fft的rms幅值
--这是rms.vhd
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity RMS is
       generic  (
                data_width   : integer := 16
        port    (
                reset            : in  std_logic;                                 -- power on reset
                clk              : in  std_logic;                                 -- Input clock
                load             : in  std_logic;                                 -- New Sample Read (Active High Sampling Clock)
                input_data_real  : in  std_logic_vector(Data_width-1 downto 0);   -- Input Data Real
                input_data_imag  : in  std_logic_vector(Data_width-1 downto 0);   -- Input Data Imag
                rms_result       : out std_logic_vector(Data_width-1 downto 0)    -- RMS result
end RMS;
architecture RMS_Architecture of RMS is
component sqrt_calc
      generic(
             data_width          : integer := 16                                   -- Size of Data (bits)
      port   (
             data_in             : in unsigned(data_width+data_width-1 downto 0);  -- Input Data
             data_out            : out unsigned(data_width-1 downto 0)             -- Output Data
end component;
component Multiplier
generic(
             multiplier_width    : integer := 16;
             data_width          : integer := 16);
        port (
             mult1_data          : in std_logic_vector(data_width-1 downto 0);
             mult2_data          : in std_logic_vector(multiplier_width-1 downto 0);
             product             : out std_logic_vector(multiplier_width+data_width-2 downto (multiplier_width-1))
end component;
signal last_load                 : std_logic;                                                -- Used to detect rising edge of load signal
signal Mult_R_R_Out              : std_logic_vector((data_width-1) downto 0);                -- The square of the Real values
signal Mult_I_I_Out              : std_logic_vector((data_width-1) downto 0);                -- The square of the Imag values
signal squares_added_signed      : signed(data_width+data_width-1 downto 0);                 -- The square values added together
signal squares_added_unsigned    : unsigned(data_width+data_width-1 downto 0);               -- Needs to be unsigned for square root calculation
signal sqrt_result               : unsigned(data_width-1 downto 0);                          -- Result of square root calculation
begin
rms_calc: process(reset, clk)
begin
if reset = '0' then
   squares_added_signed <= (others => '0');
   rms_result <= (others => '0');
   last_load <= '0';
elsif Rising_Edge(clk) then
   if (load = '1' and last_load = '0') then         --  begin on load rising edge
       squares_added_signed <= resize((signed(Mult_R_R_Out) + signed(Mult_I_I_Out)), (data_width+data_width));
       rms_result <= std_logic_vector(sqrt_result);
   end if;
   last_load <= load;
end if;
end process rms_calc;
squares_added_unsigned <= unsigned(squares_added_signed);
R_R_Mult: Multiplier
generic map (
                  multiplier_width => data_width,
                  data_width       => data_width
         port map (
                  load             => load,
                  mult1_data       => input_data_real,
                  mult2_data       => input_data_real,
                  product          => Mult_R_R_Out
I_I_Mult: Multiplier
      generic map (
        port map  (
                  load             => load,
                  mult1_data       => input_data_imag,
                  mult2_data       => input_data_imag,
                  product          => Mult_I_I_Out
Square_Root : sqrt_calc
      generic map (
         port map (
                  data_in          => squares_added_unsigned,
                  data_out         => sqrt_result
end RMS_Architecture;
发表于 2004-6-21 14:25:55 | 显示全部楼层
谁会?
--这是sqrt.vhd
library ieee;
entity sqrt_calc is
      generic(
      port   (
end sqrt_calc;
architecture sqrt_calc_architecture of sqrt_calc is
function SquareRoot (Arg: unsigned) return unsigned is
    constant AMSB: integer:= Arg'length-1;
    constant RMSB: integer:= (Arg'length/2) - 1;
    variable Root: unsigned(RMSB downto 0);
    variable Test: unsigned(RMSB+1 downto 0);
    variable Rest: unsigned(AMSB+1 downto 0);
begin
    Root := (others => '0');
    Rest := '0' & Arg;
    for i in RMSB downto 0 loop
       Test := Root(RMSB-1 downto 0 ) & "01";
       if Test(RMSB-i+1 downto 0) >
          Rest(AMSB+1 downto 2*i) then
           Root := Root(RMSB-1 downto 0) & '0';
       else
           Root := Root(RMSB-1 downto 0) & '1';
           Rest(AMSB downto i*2) := Rest(AMSB downto i*2) -
                                    Test(RMSB-i+1 downto 0);
       end if;
      end loop;
    return Root;
end;
begin
  data_out <= SquareRoot(data_in);
end;
发表于 2004-6-21 14:35:30 | 显示全部楼层
谁会?
--fft_input_binary.dat
0000000000000000 0011111111111111
1100000000000001 0000000000000000
0000000000000000 1100000000000001
0011111111111111 0000000000000000
发表于 2004-6-21 14:38:04 | 显示全部楼层
谁会?
--fft_input_binary.dat所对应的浮点值
-0.0000000116             0.5000000000
-0.5000000000             -0.0000000232
0.0000000348             -0.5000000000
0.5000000000             0.0000000464
-0.0000000580             0.5000000000
-0.5000000000             -0.0000000696
0.0000000812             -0.5000000000
0.5000000000             0.0000000928
-0.0000001044             0.5000000000
-0.5000000000             -0.0000001160
0.0000001276             -0.5000000000
0.5000000000             0.0000001392
-0.0000001508             0.5000000000
-0.5000000000             -0.0000001624
0.0000001740             -0.5000000000
0.5000000000             0.0000001856
-0.0000001972             0.5000000000
-0.5000000000             -0.0000002088
0.0000002204             -0.5000000000
0.5000000000             0.0000002321
-0.0000002437             0.5000000000
-0.5000000000             -0.0000002553
0.0000002669             -0.5000000000
0.5000000000             0.0000002785
发表于 2004-6-21 14:48:06 | 显示全部楼层
谁会?
在我QUARTUAS编译中这一行(约420) ram_length => 8);出现5、6个语法提示错误!
还有其他的老是提出少“;”的错误,但改了也没有用!!!
编译时出错可以看一下在线帮助,很有用的。
 楼主| 发表于 2004-6-22 00:22:46 | 显示全部楼层
谁会?
还有上面的代码中有一个“面容”
那里的值是多少?
发表于 2004-6-22 09:44:17 | 显示全部楼层
谁会?
那个面容本来是"8)",不知道为什么显示成了面容。
 楼主| 发表于 2004-6-23 19:20:09 | 显示全部楼层
谁会?
程序还差点调通,时间上来不赢了!
发表于 2006-8-27 23:33:34 | 显示全部楼层
许多DSP的书上描述过
头像被屏蔽
发表于 2006-8-28 09:26:11 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
GMT+8, 2025-12-26 19:25 , Processed in 0.021262 second(s), 4 queries , Gzip On, Redis On.
