楼主: jiangm_bj
verdi2009好像还没人能破解,是吧?
发表于 2009-6-17 16:23:09 | 显示全部楼层
第二个就不要下了
只不过将所有的feature打包,但是非常严重的一点是不能自定义feature
比如里面就没有nAnalyzer这个feature,所以还是用第一个吧
可以写个脚本自动产生feature
发表于 2009-6-17 16:42:24 | 显示全部楼层
可以使用的大俠
幫忙傳上一個 linux daemon "snslmgrd" 好嗎
thanks,
发表于 2009-6-17 18:32:54 | 显示全部楼层
看上去还不错的东东,先试试看了
发表于 2009-6-18 09:32:54 | 显示全部楼层
好东东........
发表于 2009-6-18 10:42:08 | 显示全部楼层
好像有问题
发表于 2009-6-18 15:37:41 | 显示全部楼层
謝謝分享!
发表于 2009-6-18 22:30:23 | 显示全部楼层
Hi! helpme to crack verdi 2009
发表于 2009-6-19 11:43:24 | 显示全部楼层
I hope this crack can work
发表于 2009-6-21 15:39:27 | 显示全部楼层
TESTED the generator works, with the one 2009.01 ( the one on rapidshare ), just search "verdi 2009 不要信元"
tar xvzf <>.tar.gz <- those you've download, e.g. I've put it to /home/<USER>/novas/
Use the second license gen to generate the full set:
novas.exe -M<MAC_ADDR> -V2009.01 -E1-jun-2010 -U20
zip that novas_license_v6.0.txt file, send to linux
Modify the first few lines only, under linux,
SERVER <HOSTNAME> <- typically different from the one we run our keygen.
then DAEMON snslmgrd add /home/<USER>/novas/bin/snslmgrd
then /home/<USER>/novas/bin/lmgrd -c /home/<USER>/novas/licnese/novas_license_v6.0.txt -l /home/<USER>/novas/licnese/novas.log
Now we've a problem here, this license will report 0x3f2, which the answer has been given out by 要你命3000 already, it's the desktop_main feature from the set causing troubles ( I guess he got the information by disassembling the binary, thanks for his hardwork).  Since the batch is generated under -V2009.01 of course the license of it would be 2009.01, which makes no senses to verdi (desktop_main are old features)
Removing the desktop_main won't work, it'd report 0x3ec again.
The solution?  use the first key gen but this time:
novas_single.exe -M<MAC_ADDR> -V5.0 -E1-jun-2010 -U20
zip that file, send to linux
At linux, replace the lines of the FEATURE desktop_main, typically looks like:
FEATURE desktop_main snslmgrd 2009.01 20 <KEY> \
VENDOR_STRING=ES=<KEY> HOSTID=<MAC> \
ck=<key>
by the new one:
FEATURE desktop_main snslmgrd 5.0 20 <KEY2> \
VENDOR_STRING=ES=<KEY2> HOSTID=<MAC> \
ck=<KEY2>
lmdown -c 28001@<HOSTNAME>
/home/<USER>/novas/bin/lmgrd -c /home/<USER>/novas/license/novas_licnese_v6.0.txt -l /home/<USER>/novas/license/novas.log
some sidetrack:
if the lmgrd line doesn't run fine, saying the port being used up, you can either reboot or you can just su to root, /sbin/ifdown <eth?> /sbin/ifup <eth?>
So hopefully there's no more needs to patch the binary anymore!
发表于 2009-6-21 15:55:07 | 显示全部楼层
BTW, there's a simpler way, someone had already mention this on cracking 2007
remove that desktop_main FEATURE also works too =)
GMT+8, 2025-10-28 02:32 , Processed in 0.019474 second(s), 3 queries , Gzip On, Redis On.
