查看: 3154|回复: 7
FSM问题
发表于 2004-4-22 15:27:46 | 显示全部楼层 |阅读模式
请教各位大虾,什么叫做verbose one-hot encoding,/simplified one-hot encoding以及one-hot with zero-idle encoding,它们之间有什么区别,哪种情况下应采用相应的FSM编码方式?
发表于 2004-4-22 23:15:35 | 显示全部楼层
FSM问题
1:?
2:简化的独热编码
3:0空闲的独热编码?就是1有效,0无效的那种?
错了就当搞笑了:)
发表于 2004-4-23 00:22:02 | 显示全部楼层
FSM问题
parameter [4:0] IDLE = 5'b00001,
S1 = 5'b00010,
S2 = 5'b00100,
S3 = 5'b01000,
ERROR = 5'b10000;
Example 2 - Parameter definitions for verbose one-hot encoding
parameter [4:0] IDLE = 5'd0,
S1 = 5'd1,
S2 = 5'd2,
S3 = 5'd3,
ERROR = 5'd4;
Example 3 - Parameter definitions for simplified one-hot encoding
The simplified one-hot encoding shown Example 3 uses decimal numbers to index into the state
register. This technique permits comparison of single bits as opposed to comparing against the
entire state vector using the full state parameters shown in Example 2.
parameter [4:1] // ERROR is 4'b0000
IDLE = 4'd1,
S1 = 4'd2,
S2 = 4'd3,
S3 = 4'd4;
Example 4 - Parameter definitions for one-hot with zero-idle encoding
The one-hot with zero-idle encoding can yield very efficient FSMs for state machines that have
many interconnections with complex equations, including a large number of connections to one
particular state. Frequently, multiple transitions are made either to an IDLE state or to another
common state (such as the ERROR-state in this example).
以上引自 《State Machine Coding Styles for Synthesis》 Clifford E. Cummings
发表于 2004-4-23 18:03:43 | 显示全部楼层
FSM问题
State Machine Coding styles for Synthesis
这本书哪里有
发表于 2004-4-23 18:07:44 | 显示全部楼层
FSM问题
找到了
5_1214_4.rar
121.29 KB, 下载次数: 16 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2004-4-26 08:34:09 | 显示全部楼层
FSM问题
多谢了!
发表于 2004-7-15 20:59:39 | 显示全部楼层
FSM问题
ths
发表于 2004-7-16 21:59:19 | 显示全部楼层
FSM问题
好东西
GMT+8, 2025-12-26 21:56 , Processed in 0.021791 second(s), 9 queries , Gzip On, Redis On.
