查看: 17573|回复: 59
应邀发2008年12月JSSC全集(需要的下)
发表于 2009-5-5 17:03:34 | 显示全部楼层 |阅读模式
1、A 108 dB SNR, 1.1 mW Oversampling Audio DAC With A Three-level DEM Technique
2、A Noise-Coupled Time-Interleaved Delta-Sigma ADC With 4.2 MHz Bandwidth, ${-}$ 98 dB THD, and 79 dB SNDR
3、A 14-b 100-MS/s Pipelined ADC With a Merged SHA and First MDAC
4、An Over-60 dB True Rail-to-Rail Performance Using Correlated Level Shifting and an Opamp With Only 30 dB Loop Gain
5、A 150 MS/s 133$~mu$W 7 bit ADC in 90 nm Digital CMOS
6、Highly Interleaved 5-bit, 250-MSample/s, 1.2-mW ADC With Redundant Channels in 65-nm CMOS
7、A 52 GHz Phased-Array Receiver Front-End in 90 nm Digital CMOS
8、A Scalable 6-to-18 GHz Concurrent Dual-Band Quad-Beam Phased-Array Receiver in CMOS
9、Transmitter Architectures Based on Near-Field Direct Antenna Modulation
10、A Compact Wideband Front-End Using a Single-Inductor Dual-Band VCO in 90 nm Digital CMOS
11、The Blixer, a Wideband Balun-LNA-I/Q-Mixer Topology
12、Class-C Harmonic CMOS VCOs, With a General Result on Phase Noise
13、Terahertz CMOS Frequency Generator Using Linear Superposition Technique
14、A 56–65 GHz Injection-Locked Frequency Tripler With Quadrature Outputs in 90-nm CMOS
15、A Fully-Integrated Quad-Band GSM/GPRS CMOS Power Amplifier
16、A Field-Programmable Analog Array of 55 Digitally Tunable OTAs in a Hexagonal Lattice
17、A Current-Feedback Instrumentation Amplifier With 5 $mu{hbox{V}}$ Offset for Bidirectional High-Side Current-Sensing
18、A Low-Noise Wide-BW 3.6-GHz Digital $DeltaSigma$ Fractional-N Frequency Synthesizer With a Noise-Shaping Time-to-Digital Converter and Quantization Noise Cancellation
19、Spurious Tone Suppression Techniques Applied to a Wide-Bandwidth 2.4 GHz Fractional-N PLL
20、Load-Independent Control of Switching DC-DC Converters With Freewheeling Current Feedback
21、A 10 MHz Bandwidth, 2 mV Ripple PA Regulator for CDMA Transmitters
22、A Pulse-Based Ultra-Wideband Transmitter in 90-nm CMOS for WPANs
23、A Fully Integrated 14 Band, 3.1 to 10.6 GHz 0.13 $mu$m SiGe BiCMOS UWB RF Transceiver
24、UWB Fast-Hopping Frequency Generation Based on Sub-Harmonic Injection Locking
25、Equalization of Third-Order Intermodulation Products in Wideband Direct Conversion Receivers
26、A Low-Power WCDMA Transmitter With an Integrated Notch Filter
27、A Dual-Band CMOS MIMO Radio SoC for IEEE 802.11n Wireless LAN
28、A Single-Chip CMOS Bluetooth v2.1 Radio SoC
29、A T-Coil-Enhanced 8.5 Gb/s High-Swing SST Transmitter in 65 nm Bulk CMOS With $-$16 dB Return Loss Over 10 GHz Bandwidth
30、A 10.3 Gb/s Burst-Mode CDR Using a $Delta Sigma$ DAC
31、A 40-Gb/s CDR Circuit With Adaptive Decision-Point Control Based on Eye-Opening Monitor Feedback
32、A 90 nm CMOS DSP MLSD Transceiver With Integrated AFE for Electronic Dispersion Compensation of Multimode Optical Fibers at 10 Gb/s
33、Fast Power Transient Management for OC-192 WDM Add/Drop Networks
34、Low-Spur, Low-Phase-Noise Clock Multiplier Based on a Combination of PLL and Recirculating DLL With Dual-Pulse Ring Oscillator and Self-Correcting Charge Pump
35、A 128 $times$ 128 Single-Photon Image Sensor With Column-Level 10-Bit Time-to-Digital Converter Array
36、A Multi-Aperture Image Sensor With 0.7 $mu{hbox{m}}$ Pixels in 0.11 $mu{hbox{m}}$ CMOS Technology
37、A 5 $mu$ W/Channel Spectral Analysis IC for Chronic Bidirectional Brain–Machine Interfaces
38、A 200 $mu$ W Eight-Channel EEG Acquisition ASIC for Ambulatory EEG Systems
39、A Mode-Matching $SigmaDelta$ Closed-Loop Vibratory Gyroscope Readout Interface With a 0.004$^{circ}$ /s/$surd{hbox{Hz}}$ Noise Floor Over a 50 Hz Band
JSSC2008年12月全集.part01.rar
4.88 MB, 下载次数: 282 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2008年12月全集.part02.rar
4.88 MB, 下载次数: 232 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2008年12月全集.part03.rar
4.88 MB, 下载次数: 251 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2008年12月全集.part04.rar
4.88 MB, 下载次数: 259 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2008年12月全集.part05.rar
4.88 MB, 下载次数: 240 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2008年12月全集.part06.rar
4.88 MB, 下载次数: 241 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2008年12月全集.part07.rar
4.88 MB, 下载次数: 236 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2008年12月全集.part08.rar
JSSC2008年12月全集.part09.rar
JSSC2008年12月全集.part10.rar
JSSC2008年12月全集.part11.rar
4.88 MB, 下载次数: 226 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2008年12月全集.part12.rar
4.88 MB, 下载次数: 234 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2008年12月全集.part13.rar
4.88 MB, 下载次数: 230 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2008年12月全集.part14.rar
4.88 MB, 下载次数: 237 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2008年12月全集.part15.rar
4.88 MB, 下载次数: 231 , 下载积分: 资产 -3 信元, 下载支出 3 信元
JSSC2008年12月全集.part16.rar
JSSC2008年12月全集.part17.rar
4.65 MB, 下载次数: 263 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2009-5-5 21:27:56 | 显示全部楼层
楼主真是太伟大了,感激,崇敬中。。。。
发表于 2009-5-6 11:47:19 | 显示全部楼层
樓主~~你是勇者!!
发表于 2009-5-7 12:23:12 | 显示全部楼层
谢谢了  这个找了好久了
发表于 2009-5-7 12:24:44 | 显示全部楼层
不知道LZ那还有其他期的没,也共享一下哈 谢谢了
发表于 2009-5-7 12:39:52 | 显示全部楼层
下JSSC就是费时间, 阿拉现在不搞这个了.
 楼主| 发表于 2009-5-9 11:17:45 | 显示全部楼层
还需要哪一期?!
发表于 2009-6-3 20:31:17 | 显示全部楼层
thank you very much
发表于 2009-7-31 10:31:01 | 显示全部楼层
发表于 2009-8-5 09:28:31 | 显示全部楼层
HP 818 号黑色墨盒
GMT+8, 2025-12-18 00:46 , Processed in 0.028220 second(s), 8 queries , Gzip On, Redis On.
